Question about Pitco Frialator PIT40SN Deep Fryer
How do you unlock fryer - Pitco Frialator PIT40SN Deep Fryer
Fryer made loud bang!!!!
If you had the fryer covered when you were using it, condensation may have formed and droplets of water hitting the oil would cause spattering. Does your fryer recommend using the cover when in use?
Apr 28, 2012 | Kitchen Appliances - Others
Commercial deep fryer keeps getting to hot, having to reset, is it possible to replace thermostat ??
Hi there.
Your fryer may have problem in cutting off the heating element power (electric fryer) or burner flame (gas fryer) for temperature regulation which is thermostat's main function.Thermostat is replaceable, you have to identify the manufacturer of your fryer to get the exact component.
Regards.
Aug 24, 2011 | Kitchen Appliances - Others
My fryer is leaking oil from the tube inside I have a Master Dean fryers
If you are leaking oil by one of the burner tubes you can replace the tank or get a new fryer. new tanks usually cost around 400 plus installation. Usually better to replace the fryer.
Tom
Jul 23, 2010 | Frymaster Dean SR42G Deep Fryer
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
We purchased new fryers that are Imperial IFS40 and the salesman was going to check them out and demonstrate the fryers by putting water in them and turning them all the way up. It got so that the water...
Fryers use 2 types of stainless steel. Get a magnet and see if it sticks to the inside of the tank. If so...that is a lower grade of stainless. Use some steel wool to clean the rust spots and cover with vegetable oil. The tanks should be ok if you just bought them.
Tom
Jun 22, 2010 | Imperial IFS40 Deep Fryer
REPLACEMENT CORD FOR DEEP FRYER MODEL #RHDF260A
solved my problem i do not know what my son did joan
Jul 05, 2008 | Russell Hobbs RHDF260A Cool Zone Deep...
WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Oct 22, 2007 | Wolfgang Puck Bistro 1700 Deep Fryer
Pitco Frialator PIT40SN Deep Fryer Logo
60 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
Joe Palazola
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
