Dell photo 944 printer paper feed
Load paper into tray and press print but the paper goes so far then stops. The printer sounds like its going through the motion of feeding the paper in and printing but the paper stays put. There is no paper stuck in the rollers so that isn't a problem.
  • 5 more comments
  • tecvmax Aug 18, 2008
    paper will not feed. goes so far down and then just stops. its trying but thats all. there are no paper jams.
  • cphilliard67 Nov 14, 2008
    Also have a Dell photo 944 that I thought something was jammed, but can't seem to see anything...Help!
  • richardedew Jan 27, 2009
    I have the same problem with my 944 printer. The printer will feed the first page, but will not print. I have tried to locate a paper jam, without success. It seems as though the paper will only feed so far and stop.
  • Anonymous Jan 29, 2009
    My Dell Photo 944 states "Clear the paper Jam, but no paper is jammed and when I press the check mark to continue - it rolls the feed roller and returns to the Clear the paper jam screen on the printer.
    How can we solve this problem - does any one know?
    ladyo928@comcast.net
  • murr9506 Feb 07, 2009
    My Dell 944 printer tries to feed 3 times then stops. Sometimes it will feed if I help it a bit, but may cause it to warn of a paper jam. It seems to be some sort of problem with the feed rollers, but I don't know how to get to them to clean or replace them.
  • Anonymous Mar 17, 2009
    same problem; any fix?
  • murr9506 Apr 14, 2009
    I have the same problem with my three year old Dell 944 printer. I have to hand feed each page and wiggle it down before the feeder roller will catch it. Otherwise, it just tries 3 times and stops. I can't get good directions on how to get to the rollers to clean them, but did see online to use warm water (not alcohol) and something like a tee-shirt to dry. Anyone know how to get to the feeder rollers on a 944?
    I'm wondering if I need a new feeder roller. I think they call this the "ADF feeder." I'm also having trouble getting information from Dell on who in the Charlotte area they would recommend for non-warranty work like this. Anyone know? Thanks!
printech
  • 159 Answers
SOURCE: Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Posted on Mar 16, 2008
adonscott
  • 106 Answers
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
Posted on Jul 07, 2008
SOURCE: mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Posted on Sep 07, 2008
  • 91 Answers
SOURCE: HP 4215 won't feed envelopes
I assume you are using the manual feed try, if so there is a tire (rubber) near the center of the tray, just use any penetrating oil (such as triflow or wd-40) and clean the tire. Same thing goes for the tray assembly, there will be one half circle tire (flat on one side round on the other its the round side that needs cleaning).
Posted on Dec 29, 2008
mohammed387
  • 1952 Answers
SOURCE: Paper Jam on Rear
clean this roller
Posted on Jan 22, 2009
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    My HP Photosmart D7260 is not printing pictures
    Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
    Please note:
    • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
    • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
    Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
    1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
    2. Lift the Out-tray and place a stack of paper in the In-tray.
      • Load the paper with the side to be printed facing down.
      • Load paper in the portrait orientation with the shortest edge feeding into the printer.
      • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
      • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
    3. Push the paper into the printer as far as it will go without bending.
    4. Lower the Out-tray.
    5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
    6. Close the main cover.
    Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
    Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
    HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
    1. Lift the top cover of the printer and remove the photo cassette from the sheath.
    2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
    3. Lift the main cover.
    4. Slide the paper width guide all the way to the left.
    5. Lift the Out tray and remove any paper that is in the In tray.
    6. Line the photo cassette up with the far right edge of the In tray.
    7. Gently slide the photo cassette into the printer until it snaps into place.
    8. Lower the Out tray.
    9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
    If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
    Step one: Reset the product
    1. Without turning the product off, remove the power cord from the back of the product.
    2. Wait 30 seconds and then plug the power cord into the back of the product.
    3. If the product is not already on, use the On button to turn it on.
    Step two: Check the condition of the paper and reload it
    1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
    NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
    2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
    3. Tap the stack of paper on a flat surface to align the edges.
    4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
    5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
    6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
    If the issue persists, continue with the next step.
    Step three: Adjust the paper settings in the print driver
    The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
    1. Open a document in the program being used to print.
    2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
    3. Click the Paper/Quality tab.
    4. Choose the appropriate paper size from the Size is drop-down menu.
    5. Choose the appropriate paper type from the Type is drop-down menu.
    6. Click OK and then click OK again to print the document..
    7. If the issue is not resolved, continue with the next step.
    NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
    Step four: Clean the rollers
    1. Turn off the product and unplug the power cord.
    2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
    3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
    NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
    4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
    5. Close the access door and plug in the power cord.
    6. Try printing again. If the issue is not resolved, continue to the next step.
    Step five: Service the product
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
    Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
    Paper error
    It sounds like the photo paper tray has gone in.Lift the paper tray and pull the blue photo paper tray all the way till it stops. Then push it back in till it clicks into place. Try printing again.
    Let me know if it works
    Jun 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Can't print onto 4x6 photo paper
    Did you try this from HP.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748340&lc=en&cc=us&dlc=en&product=1155996&rule=45149&lang=en
    I also suggest you remove the back door & clean the wheels with a clean no lint water dampend rag. Replace the door.
    Jan 26, 2008 | HP Photosmart D5160 InkJet Printer
    954 people viewed this question
    jasbo
    jasbo
