Question about Insignia LCDTV26 26 in. Television
Insignia IS-LCD TV 26 Will not turn on
Set won't turn on. Suspect cold solder joint, the problem is intermittent. Red standby led is on when plugged in, should turn blue at pwr on, but doesn't
  • 4 more comments
  • tomusa75 Jun 18, 2008
    same thing here. Red status light on front is on, but when I press the power button the red light goes away for a few seconds than it comes back. The TV won't turn on.
  • knicks123 Oct 08, 2008
    yea i got the same problem, power red light goes away for a couple secondz instead of the blue comming on
  • Anonymous Oct 12, 2008
    Same problem.....hmmmm.
  • car__34 May 11, 2010
    Jaime and lets say we want to replace the Power Supply , I am a hardware technician, I havent open the TV yet, But would like to know where to get power supply for this TVs?
    Thanks for your help
  • Jonathan Keen Jun 17, 2013
    I have this same model and replaced the two 1000uf/35v capacitors (which were bulging) in the power supply, and now it works like a charm. The replacement caps didnt quite fit in the black metal box encasing the power supply so I tin snipped some of the metal off the edge so they'd fit. Its pretty easy if you have basic soldering skills. (mind you, the fault in your tv may not necessarily be the same fault that was in mine though)
  • Anonymous Mar 15, 2014
    when i turn on the tv the standby led light red then blue and the tv is dead
  • 2,326 Answers
The power supply will need to be replace or repair if the LCD failed to switch to the blue light.
I repair these power supplies.
Let me know if you need further assistance.
Posted on Oct 16, 2008
  • DDPas16 Sep 20, 2010
    HOW DO I REPAIR THE POWER SUPPLY?
This TV (Insignia) has been recalled (Model # : IS-LCDTV26) - Best BuyAS OF 04/02/2009 is STILL holding recalls for this TV due to firehazards & power supply failure - the official report is here ->
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09183.html
Contactbest buy's customer care hotline @ 800-233-0462 to get a gift card forupto $800 if you own this TV (Insignia - Model No. IS-LCDTV26)
Posted on Apr 05, 2009
    New Friend:
I had the same problem with my tv, but I fixed it by replacing 2 bulging capacitors in the power supply (the black rectangular, metal box behind the back panel). They were the 1000uf/35v caps toward the edge of the circuit board that's inside the black case. I had to cut some of the metal on the edge of the top of said case with tin snips for my replacement caps to fit in it though. Mind you, my particular issue may be different from yours, but I've read that power supply failures are very common with this model, and power supply problems, as a generality, are related to bad caps. Good luck.
Posted on Jun 17, 2013
My 42 inch insignia will not turn on. The red light is on and should turn blue when tv is on. I get nothing. Even using remote and manual, the tv will not come on.
Posted on Apr 28, 2010
Why is it that my westinghouse 32 in LEDTV model#LD-3265 just went blank on me no sound no picture but powered up properly
Do the menus work or input labels appear when you change sources?
Have you tried unplugging the power with the tv turned on, waiting a few minutes, then plugging it back in and turning it on?
Jul 14, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
My tv intermittantly turns off, the LED red light continues to blink. Turning off and then turning the TV back on after a few moments rectifies the problem - but it will recurr after a while.
Ur power board is dying,must check replaced parts like capacitors puff up or burst open.Know how solders?Buy a refurbish power board Shopjimmy.com,Ebay.com to buy.
Jan 13, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
My 26" Insignia LCD TV will not power on.. the little light on the bottom right corner will change from red to blue but the screen itself will not make any change.
The problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board is bad. The indicator is on because the 5v standby power supply is still working at least.
Nov 01, 2009 | Insignia LCDTV26 26 in. Television
My LCT3201AD is plugged in and the standby light under the screen is on (red LED). Repeated attempts using both remote and side Standby/Power switch result in the LED turning green for only a few seconds...
Remove the power supply and replace the three (3) capacitors soldered to it. They will be rated at something in the neighbrohood of 16v. Replace them with larger capacitors, something in the neighborhood of 35v.
Jul 11, 2009 | Akai LCT3201TD 32 in. LCD Television
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Shuts off and has problems comming on
TV shuts off if it gets cold,this is the symptom of "cold solder" in power supply section and also in DM board section.needs to reworks or resolder the solder joint.
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Oct 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Standby won't go off
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 31, 2008 | Audio Players & Recorders
Tv stuck in standby
Your problem is in the switch mode power supply or the horizontal out circut.
sometimes the small CHOKE that feeds the base of the horz. out transistor has a cold solder joint.
resolder both ends first.
Thanks Guy9
Jun 10, 2008 | Televison & Video
Insignia LCDTV26 26 in. Television Logo
1,901 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
