Question about KitchenAid KESC300 Electric Kitchen Range
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
  • 10,319 Answers
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Posted on Nov 03, 2010
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Accubake SF362LXTS Kitchen Range Display completely blank
You will need to replace the control board. To access the board. unplug the unit and remove the cover on the back of the console. Here is that part you need to order.
May 18, 2013 | Whirlpool Accubake SF362LXTS Kitchen Range
My oven has a code of e2 and f6. what does this mean?
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 17, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven buttons stop working and it is in lock mode and says OFF?
Sounds like a control board failure ... should be under warranty, no?
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Whirlpool Accubake RF362LXTS Electric...
My Whirlpool Accubake super capacity 465 self-cleaning oven does not work. When started E1 -F5- appears on screen. Model# RF 386 PXGO. Serial# RJ0525903.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#FDG
Jan 02, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
Error code F6-E4
Igoogled this all i could find wea control panel fault nothing for e4
Dec 11, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
F3EO error message
Replace the oven temperature sensor.
Mar 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
F3 E4 Err
E4 error complaint whirlpool ac
Jun 03, 2008 | Whirlpool RF262LXS Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
1,673 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
