Question about Pioneer DEH-1600 CD Player
Pioneer deh 1600
I have a problem with my cd player when all the units and wire harness are fully equipped the cd player has no power......also when it is wired straight to the battery it starts to get hot and smoke comes from inside the unit
    President:
  • 624 Answers
Music good, smoke bad!!!
You fried something for sure. If it is under warranty take it back and get it exchanged. That model of Pioneer is an exchange only, they won't fix it unless it is not under warranty.
If it is not under warranty, the cost for repair will be around $100 or more, that's about the cost of a new one. This model is not worth repairing since it is so cheap to buy a new one.
If you want to try and replace the output it uses the PAL007B output IC. You can also use the PAL007C. If it is fried, it may not be possible to read the part number on the IC.
Posted on Jun 17, 2008
    Genius:
  • Pioneer Master
  • 1,550 Answers
Maybe you make a mistake and burn out the audio amplifier IC and you gotta change it.
Posted on Jun 13, 2008
I need a wiring harness for a deh 405
Here is the contact page for Pioneer. They can tell you where to buy a cable. Be aware they are not cheap.
ORDER BY PHONE 1-866-214-1310
Apr 24, 2010 | Pioneer DEH-1600 CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Need wireing diagram for DEH-1600
  • Gray - Front Right +
  • Gray w/Black Stripe - Front Right -
  • White - Front Left +
  • White w/Black Stripe - Front Left -
  • Purple - Rear Right +
  • Purple w/Black Stripe - Rear Right -
  • Green - Rear Left +
  • Green w/Black Stripe - Rear Left -
  • Blue w/White Stripe - System Remote Control (Ant)
  • Black - Ground
  • Red - Switched Power
  • Yellow - Always On Power
The Pioneer DEH-16 is the same as the 1600. The only difference is the faceplate and LEDs. It can be found at the Pioneer website.
Jun 03, 2009 | Pioneer DEH-1600 CD Player
I need to know how to set the time on a pioneer deh-1600 radio
http://www.generalmanual.com/Players/Pioneer-DEH-1600-In-Dash-CD-Receiver.htm
1.press source button and hold until unit powers off
2.press audio and hold until clock appears
3.press -> <- arrows to select hours from minutes
4.0up and down buttons to change the time.
manual can be found at above link ,hope this helps
Harry
May 16, 2009 | Pioneer DEH-1600 CD Player
Can't change time on deh-11e
Harry
Apr 02, 2009 | Pioneer DEH-1600 CD Player
I dont know which wire in the memory to connect it to my after ma
The memory wire is usually the yellow wire in the harness - it goes to a constant 12v (battery) source. That's how the cd player remembers all of your presets. The red wire (the other power wire) is connected to a switched 12v source, so it only sees power when the key is on. That is why the cd player shuts off when you turn the key off.
Mar 27, 2009 | Pioneer DEH-1600 CD Player
Pioneer deh 1600 has no power
just run both red and yellow to 12v ...
well put the red on a constant 12v source then
yellow you need to put on a 12v source that comes on and off with key ..
yellow wire can go to the fuse box and take a non-using fuse out and put wire in it and should have power .. ..
i would recommend to locate the cars original wires tho ..
i am no pro iam just an average joe but i kno from installing stereos in many many cars .. ive done hack jobs to comp ..
hope this may help you
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Pioneer DEH-1600 CD Player Logo
168 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
