Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time,
is related to the purge unit being jammed with something and not being
able to move.
Moving the print head assembly will not clear a purge unit if its
jammed with paper, paper clips, push pins, screws, cookie crisp, flower
bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it's always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark,
and other inkjet printers, is where the print head assembly parks when
not in use, also its other job is to clean and make sure the print head
is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D
models you can take out the heads just by clipping them out, and then
clean well.
Also clean the purge unit out make sure all is clean.
Thanks for using fixya....
