Question about Garmin GPS
Garmin just stop working and don't have a reset button gps
  • 130 Answers
Remove you battery and leave it out over night, and then re install it, while facing north the next day, if it fails to come on your garmen needs to be returned to garmen inst, for repair, if you have dropped it or been wet you might have to replace the unit.
hope this helps you out.
Posted on Jun 12, 2008
Last week for no reason my Garmin nuvi stopped working, i had a location entered into my GPS as I approached the half way point the Garmin froze. i shut it down and turned it back on but it is still in the...
Since powering off and on your GPS isn't solving the problem, you should attempt a RESET. The RESET procedure is as follows:
1) Disconnect the GPS from external power.
2) Raise the antenna.
3) Locate the RESET button close to the antenna hinge on the rear of the GPS.
4) Press and hold the RESET button for 3 seconds.
5) Reconnect the GPS to external power source.
The GPS will have been reset and power back on at this point. If you have problems still, contact Garmin Support. You can download your manual here.
I hope this helps - if it did, please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Garmin nuvi 350 GPS Receiver
My garmin 305 don´t turn on
I got the same issue. There is a trick to reset it (hold mode & reset buttons for 10sec, wait 10 sec, turn on with pressing power for 10 sec).
Mine is starting then once, then same problem when switching it off.
Aug 12, 2010 | Garmin Forerunner 305 GPS Receiver
Zumo 55o, reset button location?
This unit don;t have a actual reset button on it, but there;s a way you can reset it.
Press and hold the power button and the plus sign to reset the unit for about 10 seconds or more.
Jun 28, 2010 | Garmin zumo 550 GPS Receiver
My gps unit a garmin nuvi stopped working. can it be fixed?
Yes it can be fixed. Let's begin by resetting it to factory settings. Use your finger nail to gently lift the frame around the picture. It is thin so be careful to work your way around. Under that thin frame you will find the reset button. Push it. If that does not solve your problem you will have to mail your GPS in to the Garmin company. Joe
Apr 22, 2010 | Garmin Nuvi 660 GPS Receiver
Touchscreen on garmin nuvi 680 GPS stopped working
Try reseting the nuvi, there is a reset button on the bottom or on the back, some models have it on the front under the display cover.
if that doesn't help the digitizer which is the part on top of the lcd display that registers the touch could have failed and may need to be replaced.
I haven't seen many garmin repairers, you might have to get in touch with garmin about it, check ebay for replacement parts but if I remember correctly garmin takes care of it and don't distripute much parts.
Sep 10, 2009 | Garmin GPS
Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
Aug 06, 2008 | Garmin nuvi 350 GPS Receiver
Will not stay on
Connect the Garmin using the USB cable to your computer. Turn on your computer and let it boot up. Now turn on the Garmin. Does it stay on? If the answer is yes then the battery is dead. If the answer is no then you have something internally wrong with the Garmin. If the unit is still under warranty then get a RMA and send it back to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in the manual (see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Nov 13, 2007 | Garmin StreetPilot c550 GPS Receiver
GArmin c340
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in this manual (different model but same principle, see website below) for pictures:
Oct 11, 2007 | Garmin StreetPilot c340 GPS Receiver
Help no display
If you pull off the front outer surround trim panel (prize off just underneath the garmin logo) you'll find a reset button. That should fix it for you.
Sep 05, 2007 | Garmin StreetPilot c310 GPS Receiver
GPS Logo
125 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
