Question about Soyo DYLM1996 (Black) LCD Monitor
Soyo monitor sound
My soyo monitor is brand new. has built in speakers. and i cant get the sound to work
5 Suggested Answers
Sunil Panem
  • 80 Answers
SOURCE: built in monitor speakers not working
Did u check with the volume button on the side of the monitor.
Also pls check the connections and also the volume settings in windows.
If they dont work, then try with external speakers to find out if it is a problem with the mionitor or the speakers.
Posted on Feb 06, 2008
SOURCE: No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Posted on May 28, 2008
SOURCE: No Sound on Envision H22W Monitor
No you all got it wrong...they are speed holes!
Posted on Sep 06, 2008
jolvera88
SOURCE: HP vs15 Flat Monitor
It depends what computer you have, and what version of Microsoft you have. for those of you with the Presario SR1650NX computer, here is the Latest driver: Click. For the earlier driver: Click.** to download drivers for you computer go to your computers company website (Gateway, HP, Compaq, Etc.).
**I Recommend downloading the older version first, and if it doesn't work then download the latest.
Posted on Nov 16, 2008
  • 263 Answers
SOURCE: brand new monitor screen doesn't have any red
Take it back and buy a recognised brand monitor looks like yours could be a melon .Even a second hand one by Acer would be better.
Posted on Jul 29, 2009
What cables are needed to connect soyo dylm2286 so that monitor speaker works?
Hi!
For the speakers to work on your monitor you need a unexpensive cable that has on each end the same type of connector: 3.5 mm stereo jack. It is the same type of jack as on e.g. headphones.
The cable must be connected between the green output jack from the PC to the similar connector on your monitor.
Please let me know if it helped.
Aug 10, 2011 | Soyo DYLM2286 Monitor
Brand new monitor screen doesn't have any red
Jul 29, 2009 | Soyo Computers & Internet
I have no sound on my Acer monitor
ACER X223W have no speakers build in. You must use exstra speakers or a headset.
Jul 26, 2009 | Acer 22" X223w LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
Monitor INBUILT SPEAKER not working
The audio cable should be from your computer's Audio Out (Green) Jack to the Monitor's Audio In jack next to the AC connection.
If this solution has been helpful, please rate it. Thank you!
Oct 23, 2008 | HP L1908wm LCD Monitor
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Speakers dont work
They are built into the monitor, however there is a cable that needs to be connected from the speaker socket of your sound card (normally colour coded green) to the audio in on the back of your monitor.  If this is done already, you need to check your volume settings on both your PC and on the monitor (remembering to check for any "Mute" settings)
Oct 29, 2007 | Gateway Essential 500 PC Desktop
Sep 17, 2007 | Liquid Video E15LCD1 15"
Soyo DYLM1996 (Black) LCD Monitor Logo
163 people viewed this question
Top Soyo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Roy May
Govind Deepak Kumar
Govind Deepak Kumar
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
