Question about Sony Playstation 3 (PS3) Console
Getting serious I can turn the playstation itself on... but the control does not connect and the TV does not show the main menu for the playstation.... any help?
  • Anonymous Jun 13, 2008
    Two PS3, 40 gig and 80 gig, started working fine but mid movie they stopped working permanently. The power works the controller lights up and blinks, but no menu. I am using HDMI chords.
  • Anonymous Jun 14, 2008
    Same thing happens to me, i turn on my ps3 nothing shows, my ps3 controller dosen't connect and now i cant plau :(. And i also use a HDMI chord. It happened when i switched my ps3 to my HD tv. I plugged in the HDMI chord, then when i turned it on the menu screen froze...i turned it off and now i cant get it working
    Problem Solver:
  • 8 Answers
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the menu. As far as your remote control, you need to connect it to your PS3 via the the USB port in order to sync the controller with your PS3, after this you can use it wirelessly. good luck!
Posted on Jun 17, 2008
I have an e470vl vizio hdtv. i was plugging another component into the wall when the whole outlet sparked (biggest i have ever seen/felt). the tv and dvd player were connected to a power strip to that...
first of all just switch off everything then switch off the mains, open the mains socket as there might have been a loose connection to the terminals which you`ve got to tighten. also confifrm that the earthing is well connected before you switch on .
swtch on the mains then switch on your devices one by one, also confirm that the VGA cable is well connected to the display unit
Sep 17, 2011 | Televison & Video
We think there is something wrong with the video and audio plugs, that go into the tv. But were still not sure. The playstation does turn on we can hear it. But it will not appear on the tv. When I say we...
Hello, To test what the problem is, I would recommend finding a friends whole also has a PlayStation 2. Offer good company and maybe lunch to bring his/ hers PlayStation 2 over. I would then attempt to plug in the friends PlayStation 2 into your TV and attempt to play a game, If It does work then you know the problem lies in your personal PlayStation, If it does not work then the problem could lie within the TV's internals, Possible the component connections. Assuming the game does play on your Tv, I would recommend using some tape to mark your friends cords, console and power supply (don't want to mix them up) and then start by using your friends Cords one at a time to see if you can get your console working properly. Probable can skip the power supply because you mentioned you can hear the driver start.
Best Wishes and Good luck!!!
Apr 10, 2011 | Sony PlayStation 2 (PS2) Console
My ps3 says "a serious
This is one of the most serious PS3 errors you can get. You can try access the PS3 service menu and doing a restore.
How to get access to service mode
  1. Make sure the PS3 is turned off,
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps.
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Hope this helps.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my Playstation 3 the menu doesn't
Guest
If the PS3 is not loadingg the main menu this is a sign that yoou have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then you have a serious hardware problem.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 08, 2010 | Sony Playstation 3 (PS3) Console
Main ps3 menu loads up ok, unable to load game or blue ray
You need to restore file system or restore ps3 system.
Follow this guide carefully.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
My TomTom One 3Rd edition is connected to my computer, When I turn it on it tells me to wait. when the hour glass runs down the screen that comes up does not respond to tapping to get the main menue up....
Get the latest version of TOMTOM HOME
Install it and run the program.
Now with your GPS tunred off connect it to your computer via a short USB lead.
Now switch on the GPS and clikc yes when t asks if you want to connect to a computer.
TTH will now start up and from there you can update the tomtom itself.
Oct 05, 2009 | Tomtom ONE GPS Receiver
The power comes on but the HDMI is not responding?
did you have try to reset all the video settings ?? ok let's try that my name is Juan and I am here to help you and see if we can solve this with the unit off turn the main switch off on the back of the unit connect the HdmI cable to the unit and to the tv now place your finger on the front on/off switch and keep it there now turn the main switch on the back of the ps3 keep your finger on the on/off switch for about 4 seconds or until you heard one bip (but not the first bip when the playstation turns on ) ok so once you heard the bip after few seconds remove your finger from the on/off switch and this should make your hdmI to work again just wait few seconds for the signal to show up on your tv sometimes it takes about 30 seconds once you see the browser the system will ask you if you want to switch to hdmi click yes hope this can fix your problem and if it does please rate my help thanks
Mar 11, 2009 | Sony Playstation 3 (PS3) Console
Lost remote control of TV HCT model TVD 133S
you can use the menue button on the tv itself
Nov 30, 2008 | Televison & Video
Menu will not show up
Yes you can!
TRY THIS cmfin and trey!
Shut the system off in the back then un-plug and re-plug all cords.
Turn the power on in the back.
The ps3 should have a red light on in the front.
Push and HOLD the power button in front!
It will go through a red light to green beep at you then go back to red.
This should HARD reset it.
If you have ever changed tvs or played on a different tv the ps3 will sync itself to that tv.
SO a regular tv is different then my hdtv so it would need to be reset to play on a different tv!
I hope it helps!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation turns on but TV says "no signal"
You could try the screen reset..... When the consoles in standby mode... press and hold the power button for over 5 seconds till you hear a diferent kind of beep and then it runs the optimal screen settings mode.. i hope this helps
Jun 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
