Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer MONTH AND DATE ARE REVIRSED
  • Manoj Joseph
    Manoj Joseph May 11, 2010
    Hello Dear,
    Please explain properly the problem u r facing.
    Regards,
    Manoj Joseph
    +91 9352008418
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
cropp
Posted on Jun 14, 2008
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
I can't print anything off the internet MP600
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Nov 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I keyed in date time and month. I pressed enter it show out of range. What caused it? Please help
The date need to have the following values: Month: 01 to 12 Day: 01 to 31 Year: 2011 and needs to have four digets Hour: 01 to 12 (00 to 23 only works in 24hour mode) Minute: 00 to 59
Take a closer look on the hour (just 01 to 12) and year (four digits)
Mar 11, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do i set the date and time for hp officejet 4580 all in one
turn on printer, press the black tool button (beside OK).. now press OK.. press the arrow toward the right one time.. press ok.. using the number pad enter the month,date, year and time press ok...
Feb 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
Date
You can set the date and time from the control panel:
1) Press <Menu>
2) Press arrows select "Initial Setup" Press <OK>
3) Press arrows select "Date and Time" Press <OK>
4) Use numbers to enter year - last two digits <OK>
5) Use numbers for month, <OK>
6) Use numbers for day, <OK>
7) Use numbers for time - 24 hour format, press <OK>
8) Press <Stop/Exit> to return to normal function
Feb 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
Month date time on hp6310
On the front panel of the printer hit the "Setup" button. It should be under the LCD between the attention light and the arrows.
Press "6" for "Tools"
Press "3" for "Date and Time"
Feb 04, 2009 | HP Office Equipment & Supplies
Converting date of a month to last working day of the month
use the below formula to get the date of the LWD (Monday thru Friday) of the month.
Assumed that if the date in cell A1 is 6-May-2005. then formula will be
=DATE(YEAR(A1),MONTH(A1)+1,0)-(MAX(0,WEEKDAY(DATE(YEAR(A1),MONTH(A1)+1,0),2)-5))
Jan 30, 2009 | Microsoft Excel for PC
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
