Question about Kenmore Sewing Machines
I have a Kenmore Ultrastitch 8 sewing maching. The clutch won't tighten properly.
    Problem Solver:
  • 16 Answers
Has this been taken apart recently for servicing? It could be a keyed washer reversed or the limiter screw on the wrong side of a tang. It just needs to be reassembled properly.
<Ray>
Posted on Nov 13, 2010
The clutch on my Kenmore model 1249 wont tighten. Is there any way I can fix it myself?
Oh,Oh, time for a professional overhaul. Sounds like a tooth may be broken or worn. (Plastic probably) not like the old machines with metal teeth.
Jan 01, 2015 | Kenmore Sewing Machines
Clutch knob on kenmore 15814001 sewing machine will not tighten
Have you removed the inner wheel? If so you probably have put clutch spring in backwards. The washer like piece has to bent fingers that appear to fit in the center of the shaft. These should be facing out toward the tightening nut. Turn washer around and voila good to go.
Oct 17, 2014 | Sewing Machines
Wound a bobbin now machine won't sew
after the clutch knob inside the handwheel is tightened,,,
did you push the bobbin spindle back to the left?
Oct 12, 2012 | White Sewing 1766 Mechanical Sewing...
Clutch won't release
the machine needs to be serviced by a sewing machine repair shop
Jan 25, 2012 | Kenmore Sewing Machines
My bobbin thread is bunching up underneath. I have taken the bobbin out and the bobbin assembly out but it still is doing it.
Gayle,
In a sewing maching, for the thread not to bunch up, there are two thread tension tighteners. One each for the bottom and the top threads. The top thread tensioner is a nut that tightens or loosens the thread tension. The thread passes under this nut. While for the bottom thread it is two screws on the casing for the bobbin. These two screws hold a small strip of metal to the casing and the thread passes under this strip.
To be able to get proper tension on both the threads you have to strike a balance on both the top and the bottom threads. If the difference is not much then you can do with varying only one of them, usually the top one for ease of functioning.
Since you say that the thread is bunching uo on the bobbin side, ie, the bottom, means that the top thread is too tight and must be loosened. You cant do it in the first go. It may take you a few attempts to get it correct, so do not loose heart if it is taking time.
All the best.
Jan 27, 2011 | Kenmore 11101 Mechanical Sewing Machine
Clutch won't release.
This what you do, get a wide blade screwdriver, place the screwdriver blade on one of the slots or grooves on the stop motion wheel on the left hand side as you look at the machine from the end, the the top of the handle a good thump and you will find it will release, don't over tighten once you have freed it off.
May 28, 2009 | Kenmore Sewing Machines
Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Feb 28, 2009 | Kenmore Sewing Machines
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Balance wheel on sewing maching does not turn
hi have you recently refill bobbin seems like you need to reengage clutch tighten inner wheel on hand wheel or slide switch depending on machine refer to your manual good luck
mary h
Dec 27, 2008 | Sewing Machines
Sewing Machines Logo
103 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
