Black & Decker String Trimmer Cordless 12" 18V
Problem for Black & Decker String Trimmer Cordless 12" 18V
Grasshog timer
By arlyl on Jun 12, 2008
the motor runs but the head doesn't turn like the shaft broke going down to the head please help can it be replaced or is it time to buy another?
Solution #1
posted on Sep 15, 2009
Not Rated)
Technosavy
Rank: Guru
Rating: 88%, 56 votes
If you have the model # NST2018 then the only thing wrong is that a .30 cent retainer clip at the upper end of the spindle shaft is missing. A local hardware store should have one that will work. There should be a thin washer that will go between the sleeve bearing and the retainer clip that will be inside the housing as well.
Was this helpful?
Yes
No
Solution #2
posted on Jun 16, 2008
Not Rated)
hammer drill
Rank: Guru  Black & Decker Expert
Rating: 86%, 280 votes
broken spindle assy. parts diagram are available at
toolpartsdirect.com
Was this helpful?
Yes
No
Popular Solutions for Black & Decker String Trimmer
Questions and Unsolved Problems for Black & Decker String Trimmer
Do you recommend Black & Decker String Trimmer Cordless 12" 18V?
Answer
Answer
have wt3100 weedeater lawn trimmer - how to change the trimmer head -it has 2 wheel model nwt-3100
Answer
petrol tank capacity of line trimmer roybi model rlt30cet
Answer
I replaced the spool arrangement with an adaptor that uses 2 pieces of string. After years of use it... (More)
Answer
need to know how to hook up fuel lines on poulan pro ppb350
Answer
cylinder head has come loose on stihl ss56 whipper snipper
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Lawn Trimmer and... Experts
Top Garden & Power Tool Repairmen
in , CA
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
