Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire washer lid lock will not unlock after any wash cycle. How do I get the lid to unlock?
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 1314 Answers
SOURCE: frigidaire washer model #fwt425rhso
the tub is mounted on shocks if you look in side the tub near where the tub seem is take the screws out of the vane and slide it foward and take it out look in the hole for foreign objects in between the inner and outer tub then follow this procedure to check the drain pump if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jan 27, 2008
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
SOURCE: my frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Posted on Jan 26, 2010
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
Frigidaire FFLE2022MW washer dryer combo beeps twice and stops during all washing cycles after it fills with water and lid is still locked. Does anyone know how to correct this? Thanks
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire White Electric Washer And Dryer...
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Frigidaire top load washer does not spin until I depress the lid lock switch
Is the strike still in place on the lid? What is the model number?
Nov 20, 2013 | Frigidaire Washing Machines
I have a FEX831FS4 washer/dryer. The washing machine will wash and spin, but will not rinse and spin. Lid is locked.
think ur voltage is too low..usually frigidaire brand washer is 220v,..usually starting of spinning has a high ampere and it need a high volt electrical supply..try to check ur main breaker for washer only..ur lid lock will lock after 10secs when it spin fast...
Dec 02, 2012 | Washing Machines
Washing cycle has finished but now the lid wont unlock. i have tried pulling the knob out then pushing it back in. i have also tried rewashing the load but now. not only will it not unlock, but it also...
you probably have a faulty lid switch/ locking mechanism. it is all in one. if the machine does not sense that the lid is closed properly, it will not start. you can try unplugging it to see if it will release the lid lock.
Oct 11, 2009 | Frigidaire FWS833A Top Load Washer
During wash cycle the tub doesn't lock.
Lid lock may be damaged. Unplug, remove the front by the bottom 2 screws. Look at lid lock to see if it has overheated or damaged. Let me know, Thanks, Sea Breeze
Mar 10, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Lock won't release on washer
Sometimes if you unplug it from the wall outlet for 5 minutes, then plug it back in and let it go through a fresh startup cycle then it refreshes and resets itself and may unlock switch.
Jan 18, 2018 | Frigidaire FLGB8200DS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
726 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
