Question about LG Art Cool LA181CNW Split System Air Conditioner
Lg muilty system midwall unit error code c1 - LG Art Cool LA181CNW Split System Air Conditioner
  • 2,133 Answers
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
sensor
Posted on Jan 03, 2011
Did new installation of ACI24H1P INVERTER MIDWALL NOW it shows F1 error
I'm not finding that model but yes, unlikely, if two separate outdoor units that both are damaged. Either there simply isn't one and the configuration is not right or the connection is loose or sensor is not secure.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 26, 2017 | Inverter Heating & Cooling
How we repair LG ac showing C1
try switch the unit off till ice melts and try running the unit again after. if the ice is till coming back check the filters are clean and outside coil clean. sounds like a restriction in piping,possibly a blockage.
c1 err caused by the indoor pipe sensor being out of spec, possibly due to the ice buildup.
Apr 24, 2016 | LG Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
What is a code c1 on a samsung mini split?
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
I have a "cl"or "c1"
C 1 means indoor thermostat sensor defective.
Dec 11, 2010 | LG LA185HV Split System Air Conditioner
C1 error on lg 18 artcool
C-1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Dec 11, 2010 | LG Heating & Cooling
LG Artcool Error Code C1. What does this mean? (Background info A/C unit works fine, cools as normal. Installed 2 years ago)
Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Nov 08, 2010 | LG LA185HV Split System Air Conditioner
LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Mar 02, 2009 | Heating & Cooling
LG Art Cool LA181CNW Split System Air Conditioner Logo
1,053 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
