Question about Samsung Televison & Video
Samsung LNT4042HX/XAC the set refuses to switch on, wheter you use remote or set button. It you are lucky it may start clicking and does it for 30 min and it is getting longer. I need expert help!
  • Samsung Master
  • 11,800 Answers
What has happened: a big part of the tv has failed - usually in this model is the T-Con board - and that part has started to act like a short, drawing huge amounts of current and preventing the rest of the tv's components to function correctly. This in turn has triggered the protection system of the power source which has forced it to shut down. If, despite the obvious bad state of the tv, you have attempted to start it the protection system gets reseted and disabled - this allows the power source to start functioning; that in turn causes the T-Con board to get powered and it absorbs so much current that the voltage drops so low that the power source can't operate no more so it just shuts down; that cuts the power to the T-Con board and the current to it drops = the voltage starts to raise = the power source starts to work again and the cycle begins again - this is the clicking you hear. Eventually the protection system kicks in and the power source is shut down for good.
This abnormal functioning massively overstressed the still functioning parts of the tv - every time you have tried to start it the damage got bigger and the protection system had a harder job to activate and protect the tv. Stop doing that, in fact unplug the tv from the wall immediately.
To identify the faulty board with certainty the tv must be opened and the voltages on the power source checked - the one that is close to 0 will point to it. This is a very skilled job that should be left to someone with experience. Call a repairman and be prepared to pay around $600.
Posted on Nov 02, 2010
  • Jason Chapman Oct 29, 2012
    The above post isn't true.On the power board you have small capacitors, about 4 in total need to be changed, I took my power board off and went to a local repair guy who soldered new capacitors on for 20 bucks, I did purchase them from radio shack though for 2 bucks each :D
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LNT4042HX HD Television
the power supply board needs to be replaced, VERY common problem.
Nov 11, 2009 | Televison & Video
I have LNT4042HX\XAA. When I try to turn power on, I get many clicks (on and off). Never turns on. What to do?
You probably have a bad Power Supply and or a bad Main bd. Have a trained Samsung tech troubleshoot the set.
Jul 08, 2009 | Samsung Televison & Video
Tv doesn`t start
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Jun 03, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Remote problem
You get lucky once in while right?-lol
You need to do 1 of 2
get universal remont-are use the 2 you have but be sure you enter the source button on both-
Sep 05, 2007 | Samsung AH5901169L Remote Control
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. check picture settings or input or source The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
Televison & Video Logo
723 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
