Question about Canon Selphy CP400 Thermal Photo Printer
Cannot install Selphy CP400 onto a Windows 7 (64 bit)machine.
Download vista 64bit drivers (cp400x64mux.exe). Extract these using winzip or winrar or 7zip. Rightclick CNYCPINS.EXE, click Properties, click Compatibility tab, and select Vista SP2 mode. Connect printer, rightclick CNYCPINS.EXE and click 'run as administrator'. Printer is now installed, works fine on my Win7 Home Premium 64bit.
Posted on Nov 03, 2010
  • 1 more comment
  • kpraveenthom Aug 06, 2011
    Hi, your advice was absolutely helpful. i was cracking my head to install this CP400 on my win7home 64bit. following your instruction, it gets installed fine. guess this is the method to install all the old gadgets whos win7 driver are not there. thank you dude!
  • David Lather
    David Lather Aug 27, 2014
    Your "ix" added years of life to my Selpohy CP400. Thank You
  • David Lather
    "ix" = "fix" My Bad
  • 1,218 Answers
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Windows-7-and-HP-Printer-Scanner-C4100/m-p/371619#M22106
Posted on Nov 12, 2010
  • 421 Answers
SOURCE:
I have the Selphy cp1200 photo printer; the ink cartridge is postcard, the paper is postcard, I keep getting the error "paper is not loaded correctly". Please advise, I know it is loaded properly.
Are you using Canon 4x6" PCP-CP400 Postcard Size Paper Cassette for SELPHY CP900/CP910 Dye Sub Printers??? Is the paper Matte or Glossy
Is the paper upside down?
Did you fan the paper at least 3 times?
Aug 24, 2018 | The Office Equipment & Supplies
I have no disk to put the printer on my computer
Click on this link, then drivers and software, select operating system and select your driver.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_es2#DriversAndSoftware
If link does not work copy and past in to browser.
Hope this helps.
Regards,
Apr 14, 2011 | Canon SELPHY Compact Photo Printer
What computers is this printer compatible with?
System requirements:
Computer: PC or Mac
Operating System: Apple MacOS 9 • Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows 98 Second Edition • Microsoft Windows Millennium Edition • Microsoft Windows XP Home • Apple MacOS X
Jan 31, 2011 | Canon Selphy CP400 Thermal Photo Printer
We recently installed Windows 7 onto our computer. My Canon Selphy CP760 Compact Photo Printer does now not work. What can I do about that? We previously had windows Vista.
Every time you install a new operating system, or reinstall one, you have to install the printer drivers. Printer drivers never come with the operating system files like hard drive drivers, video drivers, audio drivers, network drivers and stuff like that. OS manufacturers know that you are going to need that stuff no matter what, and for the most part, there are not that many manufacturers. But printers are different, you always have to install them. Here is the best printer driver I can find for your printer with Windows 7: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp760#DriversAndSoftware
Please note: This is a 32 bit driver (the link on the page) and Canon does not have a windows 7 - 64 bit driver yet. If you need a 64 bit driver, use the Vista 64 bit driver and install it in compatibility mode. Windows 7 compatibility mode is excellent...HP still does not have a Windows 7 driver for my printer, and I run mine off of a Vista driver and it works great. If you try to install it straight, it won't install, because most vista software is stricly Vista compatible. You have to open the folder, find the setup file that begins the install, and right click, and check compatibility options. You get a box that opens and you can check exactly what version of Vista with exactly what service pack...and be sure to check the little box that says install as administrator. If the install fails, and you can't find how to do this, do the install again...if the install fails I think it is 2 or 3 times...Windows will automatically pop up the box for you. Windows 7 is very intuitive....I LOVE IT!
If this post has helped you, please remember to vote.
Jan 25, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Paper stuck in the printer because of dead camera battery
Been there before. There is no easy way to do this however you can call canon and there is a reset switch pattern that will rest the memory in the machine and run a self test at start up this may help
Nov 06, 2009 | Canon Selphy CP400 Thermal Photo Printer
Would like a start guilde
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=11047
go to this website,,select the correct operatiing system and u will fing the product manuals
best of luck,,giv a good rating and keep me posted
May 19, 2009 | Canon Selphy CP400 Thermal Photo Printer
How do I load the paper in the canon selphy cp400 printer. This was given to me with out the operating manual.
You can download the User Guide (in PDF format) here
Just scroll down to the Guides & Manuals Section and download the file Named :
Compact Photo Printer SELPHY CP400 User Guide
CP400UG-EN.pdf
Nov 30, 2008 | Office Equipment & Supplies
Canon cp400
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=118&modelid=11047
Jan 16, 2008 | Computers & Internet
Canon Selphy CP400 Thermal Photo Printer Logo
5,573 people viewed this question
Clive
Clive
old marine
old marine
