Question about Kodak EasyShare V603 Digital Camera
Zoom My camera will not turn on or off with the zoom stuck open. I have put in a new battery in the bottom of the camera and that did not work either. What could be the problem.
    Problem Solver:
  • 6 Answers
Please check the battery contacts inside the camera. Do they look gold and shiny? Or do they look a little dirty? It wouldn't hurt to try cleaning them with a pencil eraser, just don't leave any tiny pieces of eraser in the camera. Hope this helps!
Posted on Jun 29, 2008
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
My batteries run out on my samsung d1070 camera and now the zoom is stuck and the camera wont turn on it just beeps
I suggest that you place the camera in a safe place ware the extended lens will not be damaged, than remove and recharge the battery. After replacing the battery, the lens should automatically retract and you should be good to go. Hope that this helps, God bless...
Aug 16, 2009 | Cameras
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom Error
I have had the same problem with my camera. It mostly occurs when my battery is going dead. It will go in and out while trying to turn the camera on and off. It will get stuck open and stuck closed and sometimes half way.
I put new batteries in, and it works like a charm. I can now tell my battery is going dead when it starts to behave that way.
Apr 19, 2008 | Olympus SP-350 Digital Camera
My camera wont turn off
I've purchased several of these cameras used as we liked our first on and it eventually failed with this same problem. I have had four of these now and they all end up with this same problem. Take the battery out then turn the selector to any new position and then off, put the battery back it and the lens should recline and camera turn off. One of the cameras would then work for a while after doing this but then hang up again. I think this is a very common problem based on my experience but no other confirmation than yours.
Jun 09, 2007 | Canon Sure Shot 105 Zoom Date 35mm Point...
Kodak EasyShare V603 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
