Question about Dell (0E828) for Latitude C610 Modem
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my desktop.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 296 Answers
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Posted on May 13, 2016
5 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: internet problem
try to download the software and reinstall it.
make sure the timer is off.
http://www.soft32.com/download_170669.html
Posted on Oct 16, 2008
tech curly
  • 298 Answers
SOURCE: connecting dsl modem to dell latitude laptop
If your DSL modem does not have a phone port or if it has one but it's bigger it's not a phone port, it's called an Ethernet port. Most of the DSL modems/routers they have an Ethernet port. This is how it looks like click here. If this the port that you have on your modem, the cable that is also in the picture is what you should be using to get the laptop connected to the modem. The cable is called an Ethernet cable. And your laptop must also have this ethernet port.
If you have more question please let me know. Just reply to this post.
Posted on Feb 15, 2009
  • 102 Answers
SOURCE: can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
Posted on Apr 07, 2010
  • 10406 Answers
SOURCE: I have a dell Inspiron 5000 and want to connect it
Your Internet Service Provider will have provided a DSL-adapter to you.
Connect one 4-wire cable from the adapter to the telephone wall-jack.
Connect one (8-wire) Ethernet cable from the adapter to the network port on your Dell.
Posted on Dec 20, 2010
Can get router to connect to Internet
Cathy, your router does not connect to the internet, your modem does. Are you trying to use wireless, or is it hard wired like using an eithernet cord? If so then make sure the eithernet cable is hooked up properly and that it is goodIf it is good then try to connect your modem directly to your computer by using the eithernet cable. If that works then you know that the signal from and too your computer is working properly. Next go to your control panel and open network and sharing center. Go to set up a new connection. If that doesn't work then you might suspect a defective router. By the way has it worked before or is this a new setup?
In order to help you through this you need to be more specific with what is going on with your system. What brand of router is it? Depending on what brand there is a web address you can use to be able to access your modem.
Good luck,
Marty
Jul 19, 2014 | Computers & Internet
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
I can access internet direct. But no internet Model dir 615
Whilst the router is turned on, try to reset the router by pressing and holding the tiny reset button at the back of our dlink router using a paperclip. Then try again.
Jan 02, 2010 | D-Link Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Can't send/receive fax
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Jan 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
How to conect my westell 327w to my cable box
looks like this 1)cable modem
2)eithernet cable to westell gatewas port 1
but before you do this lob into the properties manager with just one computer connected directly to the gateway any port but 1... cancle dsl connection go to advanced wan click wan and from drop down choose bridge or on pop up which ever is easier.. then inable wan on eather port 1 on the drop down... Now config the rest of the settings the way you choose them and when your all done plug the eithernet cable into port 1 and let the cable modem sync with the gateway......
Jan 24, 2009 | Westell Wirespeed VersaLink...
Smc289wbr wireless could it be a cable problem
re-configure the router properly and get the right details from your isp.(internet service provider)
Oct 13, 2008 | SMC Barricade g SMC2804WBR Wireless Router
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dell (0E828) for Latitude C610 Modem Logo
201 people viewed this question
Alun Cox
