Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
I'm getting an error code 02-403 on the Betacam UVW-1400. Can you tell me what that means?
welcomejee
  • 10594 Answers
SOURCE: Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Posted on Nov 26, 2008
  • 78 Answers
SOURCE: digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Posted on Jan 31, 2009
  • 221 Answers
SOURCE: Mensaje error 02-395 on a Sony BETACAM UVW 1800
error code 02-395 points to a problem with one or both reel motors. a good technician should be able to fix this easily.
Posted on Feb 20, 2009
  • 221 Answers
SOURCE: Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Posted on Aug 26, 2009
SOURCE: error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Posted on Nov 25, 2009
Is it necessary to consider the edges while calculating the areas &volumes of a solid
The edges are the limits and so, they are the dimensions that you use. In that respect, they must be considered.
Oct 25, 2014 | Sony Nice Betacam Sp Uvw 1400 Video...
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
Tape betacam not run
Do you get any Error mesages on the display ?
Sep 15, 2009 | Sony UVW-1800P VCR
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Jan 21, 2009 | Fuji M321SP Betacam Tape
Error code 02-694
Apr 13, 2008 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
652 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
