Question about Philips DVP5140 DVD Player
Philips PET824; the left third of the screen is Green
I have a Philips PET824. The left third of the screen is Green, but you can see a shadow of action behind the green courtain. I took out and re-inserted the 4 cables in the sockets inside the screen, but nothing changed. Perhaps the driver-IC is out of order.
Thank you for your time,
Florin
  • 8,596 Answers
Call Philips to see if you are in warranty if the reset fails
Posted on Sep 04, 2008
Philips 30PW850H 30" TV screen is completely
hi,
normally color crt tvs have three guns such as red green and blue. when the voltage at the cathode any of these guns go to zero that color will lead in the screen.
in ur case the green cathode voltage is low. that's why the is green on all over the screen.
if it suddenly came then there is a possibility of dry soldering in the pcb behind the picture tubes neck. we called it as base board. which consist of three transistor or one ic for cotrolling cathode voltage of the guns .
if u have a soldering iron the open ur tv and try to re-solder components in the base board. mainly the component with three leg ( if transistor). if there is ic it will have more than 6 legs . if you can try to re-solder all the points. Be care-full that dot make short circuit when soldering. after care full soldering power on the tv and watch the scree. you problem Will solved.
if u need any further assistance from me, feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips 30PW850H 30" TV
Theres a shadow on 1 third of screen on left , its...
the light tunnel is collasped or needs adjustment.
May 19, 2010 | Office Equipment & Supplies
I've tried all the tips. Do you know where I can
It's not operating perfectly. It doesn't always load the DVD on the first try. But once it's loaded, it plays through okay. I just kept moving the laser unit back and forth and cleaned the lens as recommended. I got the unit to where it would keep trying to load the disc and finally it recognized the DVD and started playing.
Jun 16, 2009 | Philips PET824
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Philips 60P8341 60" Rear Projection...
Screen has a "haze" over 1/3 of it...rest is okay
This may be due to a bad contact in the connector. If you unscrew and remove the back cover, there is bunch of wires coming from the LCD with a male or female, I forgot, connector on the end, which plugs into its counterpart on the main board. That connector may not be fuly plugged in. The chance that this is indeed the case is no more than 10%. Unfortunatey it looks like this the electronics failure - 70% or LCD itself - 20%
Dec 03, 2008 | Philips PET824
Hi How can i change the region on my Phillips portable DVD pet824. i live in sydney Australia we use region 4 thank samis
Multi-Region:
Switch player On and Open tray door
Press Setup on the remote control
Move menu selector down to Preferences and press Right arrow
Press 2, 1, 2, 2, 2 and 5
Press Left Arrow
Press Down Arrow
Press 0 when the screen displays region code
Press Setup to exit
Jul 13, 2008 | Philips Televison & Video
Green Shadow
The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
Dec 31, 2007 | Philips 50P8341 50" Rear Projection...
Philips DVP5140 DVD Player Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
