Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
TV Won't Turn ON-Sony FD Trinitron WEGA 30"
For the past few months it took longer for the picture to display on my TV. Then suddenly while we were watching our TV the other night it turned off on its own and since then have not been unable to turn it back on. There is a small red light (I think the light is labled "Stand-By Light") on the bottom right hand corner (if facing the TV) that will blink three times when pushing the power bottom and will go out and the TV won't start. I have unplugged the TV and tried starting it to no avail and reoported the incident to Sony's Service department and they could only recommend brining it in to a technician.
Is the potential fix worth the cost of fixing? I purchased the TV 3.5 years ago for ~$1,000 and I will be pretty irritaed if I need to throw it away after such a short time.
  • psgrove Jun 12, 2008
    I read a similiar issue and the solution was Flyback Transformer. What are your thoughts regarding that solution?
    I had called a local repair man (recommended by the Sony Servicce Line) and let him know the issue as well of what I read and he mentioned the prospect of it being the Flyback Transformer he quoted labor to be $250 and the part (though he couldn't find a price)in the range of another $200-$300. They would also charge a diagnostic feel of $95 so in total it would cost me nearly $700 to fix a TV I purchased for $100 3 years ago. Wanted to get a second opinion of whether the issue appears reasonable and the estimate to fix such an issue would be in that range.
    Thanks,
    Patrick
    I called the SONY Service/Help Line and let them the number of blinks (3) and they did not have problem that corresponds to 3 blinks. They instructed me to unplug the TV and plug it directly into the wall and wait a few minutes and after doing so the problem was not solved.
    Brigadier General:
  • 3,614 Answers
In some problem concerning on the flyback area, first check the the rectifier diode, rectifier filter capacitor, could be on this parts has a problem...
Posted on Jun 13, 2008
  • 4,234 Answers
The 3 blinks are a diagnostic code indicating the circuit that triggered the shutdown. In this case it indicates an over-voltage condition. There is a problem in the power supply area. I will need to look up your specific model to provide you with the details. As long as the flyback transformer is OK, the parts cost will be in the $25 range. The flyback could increase the parts cost by $75-$120. I will try to provide a more exact parts list and cost soon.
Dan
    President:
  • 2,712 Answers
The cheapest (and easiest ) troubleshooting to do would be a hard reset: Unplug the TV from the AC power source, remove all cables running from the TV. Wait about 4 hours minimum and then reconnect to AC source and redo the cables. If that doesnt work, then you've most likely got issues with the power circuitry/components.
If you purchased your TV for just $100 3 years ago, the I think you've got your money's worth for it. Its probably time to move on to a new one.
The reason I say that is because any repair on this unit will be a minimum of at least about $100 just to run diagnostics and find the cause of the issue. Repairing and parts will cost even more.
I could give you a list of things that could be wrong, starting with the fly back auto transformer, or any number of capacitors on the board, but it would not be worth your while, especially if you have no prior experience fixing CRT's. They are notorious for carrying high voltages even when unplugged...voltages that can kill.
My honest advice would be to simply purchase a new TV.
  • Swilin Sampson
    Swilin Sampson Jun 13, 2008
    If you feel that my solution / advice helped you in any way, kindly take a moment to "Accept" my solution. Thanks!
    Genius:
  • 1,036 Answers
It would certainly be worth your time to describe the problem to local repair technicians over the phone.
Very often a replacement board is all that is needed, and if they own premesis, you can take it to them.
It will certainly be cheaper than $1000.
Posted on Jun 12, 2008
  • Richard Perkins
    Richard Perkins Jun 12, 2008
    You mentioned in your first post the cost was ~$1,000, yet in the second post $100.
    If it is the latter, then you may have to cut your losses on this one.
    As mentioned above, there are other faults known for this unit, so if one is repaired, there is no guarantee that something else will soon go wrong with it.
    It may be time to weigh up the unknown costs and hassle,versus a sure replacement with at least 12 months guarantee.
    Sorry this is not a quick fix for you.
  • 1,879 Answers
The tube failed to project image, ask sony if they can provide an estimate of the fixin' cost then decide.
    Master:
  • 638 Answers
TRY HARD RESET.
  • 3 more comments
  • hemant somaiya
    hemant somaiya Jun 12, 2008
    YES DEFINITELY ITS WORTH CALLING A TECHNICIAN .THIS IS NOT A MAJOR PROBLEM.IT WILL NOT COST U VERY HIGH.
  • hemant somaiya
    Sounds like you have a shutdown condition in the power supply section.Your gonna need a service manual a vom and possibly a good scope. Theres not much you can do as too look at it and see a bad part. And theres not alot you can check staticly without a service manual. Although there is a common problem with this chassis as were in some of the older models of sony.. the Horizontal driver transformer as well as the regulator ic has a cold solder joint on them. Good luck
  • hemant somaiya
    This is what you should do, call Sony TV techs 1888,989,7669 give them the model and serial number then tell them how many blinks, they will suggest IC-numbers on the Silicone board, See if you can locate them, its is a commen problem they already know about it, then before u hang up as for the part number then u can cross refference the sony part number with the accual part number. They will give u numbers then u have to figure out what they are maybe its on the part itself if u can make it out. Then find a parts distributor and replace them. Most likely the parts range from 6-12$ just becareful with the board, make sure u dont break of any small resistors. Or if ur not really tech savy should take it to a local service tech
  • hemant somaiya
    Additionally, the number of times the LED blinks is a code as to what the problem is specifically. SO SPECIFY THIS TO THE TECHNICIAN CLEARLY.DO NOT THIS PROBLEM WILL NOT BE TO EXPENSIVE FOR YOU TO GET REPAIRED.RATE THIS SOLUTION AS "FIXYA" IF THIS HELPS U ANY WAY TO ENCOURAGE US TO SOLVE MORE N MORE PROBLEMS LIKE YOURS.FEEL FREE FOR FURTHER ASSISTANCE.
  • hemant somaiya
    LET ME KNOW NOW ITSELF WHAT HAPPENED SO I CAN ASSIST U MORE ABOUT THIS. THANK U FOR USING FIXYA.
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
SOny FD TRINITRON WEGA XBRKV-40XBR800....IT STARTS SOMETIMES AND THEN SHUTS OFF ALL THE SUDDEN. NOW IT WONT TURN ON BUT FOR A FEW SECONDS AND SHOWS RED LINES ON THE SCREEN AND THEN SHUTS OFF. LIGHT ON...
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
Oct 16, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron wega KV-XR TV
Activate / de-activate by pushing display button on any Sony
remote control........................T.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
562 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
