Question about E-Machines M2000S 15.4" LCD Monitor
Display. The display of the screen blinks lightly, the brightness going up and down slowly, before the entire picture starts begin to flicker, the whole display moving up and down. Please, help me fix this.
Hi Danny,
Sounds as if you may have a problem in the power supply or inverter. If you have any electronic skills, you might open it up and check for swollen caps or cold solder joints in the inverter or pwr supply circuits.
Good luck
electrotech
Posted on Jun 13, 2008
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
How do I get rid of a blank screen on my laptop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 16, 2009 | Dell Inspiron 1501 Notebook
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
My brightness is very low. I can't see anything
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 14, 2009 | Toshiba Computers & Internet
Blinking black in play mode!!!! PLEASEEEEE HELLLPP
If this is the same as my Nikon this is the overexposed highlight display option.
This shows areas of the photograph that are overexposed slightly.
On my Nikon I use the up and down arrows on the back to cycle the LCD display options.
Stop when you get a display that does not flash.
Jul 06, 2009 | Nikon D40 Digital Camera
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 24, 2009 | Acer Aspire 5735 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Screen will not light up
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 04, 2009 | Acer Extensa EX4420-5239 Notebook
Computers & Internet Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
