Question about Dell InspironTM 1501 Notebook
I accidently pressed caps lock and f1 at the same time and the screen went black i dont know what to do
    Guru:
  • Dell Master
  • 2,178 Answers
Reboot the computer by holding the power button down until it shuts off.
Posted on Nov 02, 2010
    Sergeant:
  • 281 Answers
Reboot, go to safe mode try to see if there is a display setting to reset that or do a system restore.
How to switch off the right most LED right of HP 505130-371 keyboard
what PC, the pc has a name and model number?
and the light has a name.
that number decodes to USB Desktop keyboard. COMPAQ
my guess is that is the power lamp , if you dont like power on
then use black paint or electricians tape to black it out.
https://h30434.www3.hp.com/
start the computer, in windows press F1
in the box type keyboard.
numlock , caps lock, USB poweroK
somethiing like this is the LED order top right.
Jun 28, 2017 | HP Computers & Internet
F1 key - accidently hit the duplicate, how do I undo this?
Hello!
You can toggle these settings by using he Fn key in conjunction with F1. If using Windows 7, you can try using the Windows Key + P to bring up the projector options, duplicate being one of them. Alternatively, you can press Windows Key + D (shows desktop) and then right click anywhere there is NOT an icon and select Screen Resolution. Under "Multiple Displays" you can select the option you are looking for. Hope that helps!
Sep 03, 2014 | Dell Inspiron N4010 Notebook
My daughters desk top computer will boot up when I press f1 and then it shuts down and brings me back to a black screen and tells me to hit f1 and reboots. When the windows does come up I dont have time to...
Remove the battery from the motherboard and check that it has 3volts or above. if not then replace it. That will cure your pressing F1 to continue all the time. As for the restarts then you will need to turn off Automatically restart in the control panel,system section. To do this you will need to boot into safe mode. Tap the F8 while booting until you get a black screen with white type on it. Its first option is to boot into safe mode. hit enter on this screen and windows will start with no drivers loaded. the screen will appear very large. navigate to the control panel as mentioned above and untick "automatically restart". Ok that and reboot normally. now you will most probably get a blue screen of death. note the first stop code. it will appear something like 0x000000??. Its the last two digits that are the clue to why this is happening. Google the stop code and you will now know why this is happening and do something to stop the problem.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
I have a compaq presario 1237, and it will not boot, when started it goes to a black screen and has f1 or f10, it also says error 0271, check date and time settings, i have went and set default settings...
Hi
please try this
press the power up key as well as the F8 key both together
then if you get into the repair options
choose the last know good configuration option
windows will then restart and try to take it back to when it was ok
if this has helped you please let us know
so that we may be able to help others
many thanks
Jul 18, 2011 | Computers & Internet
My problem is that f1 broblem
Are you sure that it isn't your keyboard that is malfunctioning, maybe it has an F-Lock key. Most wireless boards have it to prevent you from accidently preesing F1 all the time. If your keyboard has an F-Lock key press it to diactivate it then F1 should work again.
Feb 21, 2011 | Microsoft Windows 7 Home Premium 64BIT...
My fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
I dont know anything about cap locks i have to get a new password every time i log in to facebook and i dont know why they keep rejecting my password HELP
Caps lock is that key on the left side of your keyboard. When pressed, it makes all letters that are typed in into uppercase letters. For example; without caps lock pressed: "pressure". With caps lock pressed: "PRESSURE". If it mentions something about passwords being "case sensitive," this means that an uppercase letter A (A) is recognized differently than a lowercase letter A (a). Since you can't see your password being typed, it is important to make sure caps lock is not pressed. If this becomes too complicated, open up MS Word, notepad, or wordpad and type your password there so you can see it, then copy and paste the password into the password space on facebook. Good luck with that.
Nov 15, 2008 | Computers & Internet
HOW TO SAVE NOTES ON A CALCULATOR?
There is no note program. You can hit [2nd] {STRNG} [F1] (type text with A-LOCK) [F1] [STO->] (type name with A-LOCK) [ENTER]
To view:
[2nd] {RCL} (type name with A-LOCK)
or
[2nd] {CATALOG] [ALPHA] <P> (hit down 5 times) [ENTER] (type name) [ENTER]
Turn off caps lock next time.
Oct 29, 2008 | Texas Instruments TI-85 Calculator
Caps Beep on and off driving me mad
Hold your NUMLOCK key down for 5 seconds until you hear a beep. Problem solved!
Oct 18, 2008 | Logitech Computers & Internet
Dell InspironTM 1501 Notebook Logo
44 people viewed this question
Alun Cox
