Question about Amana Kitchen Ranges
Amana self cleaning oven - latch is stuck - Amana Kitchen Ranges
  • 426 Answers
Make sure that everything is turned off then the saftey latch should release,
Posted on Jun 13, 2008
Locked oven
With a heavy wire or coat hanger , slip the wire through the top center of door to hopefully pull latch to the left to release latch.
May 27, 2013 | Amana 4.8 cu. ft. Self-Cleaning Electric...
Oven sef clean latch locked but door is open and I cannot clos it. I inadvertantly urned it to self clean and openedthe door and the latch is locked in self clean position. How do I release the latch so I...
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Jun 16, 2010 | Kitchen Ranges
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
May 07, 2009 | Amana ACF3355AS Gas Kitchen Range
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Apr 17, 2009 | Amana ARGS7650SS Gas Kitchen Range
Need to know how to operate the self cleaning on my amana gas oven
Close the oven and the associate latch ( near the handle) then select the self cleaning option on the control.. Let it run thru its cycle.. when it is complete and cooled down enough.. the door latch will release and allow entry into the oven.. Hope that helps..
Aug 28, 2008 | Amana Kitchen Ranges
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
F9 code
F9 is a Door latch failure need to replace door latch or check wire or latch motor
Dec 13, 2007 | Amana AOCS3040 Electric Single Oven
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Kitchen Ranges Logo
345 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
