Question about Chieftec Dragon
4 - 5 1/2 Bay holders
Sir I have a Chieftec-TX Tower - The only number that I could find are on the door (2BD-601A-COM01-X) 8" W X 19" L X 21"H. IT HAS 4- 5 1/2 bays and 2 - 3 1/2 bays. the holders measure 141 mm long X 22 mm Wide. the plastic on the holder is 111 mm and the medal clip is 30 mm. are these clips available? If so I need to know wher to purchase!! On the clip is CHEFTEC-TX and TOOL:4 CAV:7
Thank You
Virgil New
208 Marie Antounette St.
Lafayette, La. 70506
peten50@cox.net
3379844325
    Genius:
  • 1,027 Answers
You may want to try the customer service section at Chieftec.
http://www.chieftec.com/
They just have email service, as they are china based.
Posted on Jun 13, 2008
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Replacement Door for XION case
Contact support to see if they will give you a replacement, if not, you can check e-bay to see if they have spare parts otherwise you might just need to buy a whole new case.
Dec 17, 2009 | XION II Black Pearl ATX Mid-Tower Case
On a lighting tower i turn on 1 light and it draws 9amps when i turn on 2 they draw 30 amps and blow 15 amp fuse why ?
Why are you blowing a 15 amp fuse or why is your machine drawing so much current?
1:The fuse is blowing because you are drawing enough current to blow it.
2: Your computer, no matter what make or model should not be drawing that much current, your wall outlet is typically 15 amps.
Your power supply is most likely the culprit and may have damaged other components of your machine i.e the motherboard.
Disconnect the computer from the outlet, open it up and inspect it for burn marks, sniff for odd burnt smells.
I think you need a new power supply at the very least and maybe more.
Sep 03, 2009 | Chieftec Dragon - Lighting Yellow...
Where is the fuse box for Suzuki Grand Vitara. Dated on the registration plate (driver's side door) Dec 2001. Hint, IT'S NOT UNDER THE DRIVER'S DASHBOARD AS THE MANUAL INDICATED
Hi I'm litoshop there's one under the hood in the right side near the shock absorber tower and under the dash you find the relay block and some vitara have a fuse box in the lower left side behind the coin holder pull the coin holder and behind that you'll find a fuse box good luck if this information has been useful please let us know thank you.
Aug 29, 2009 | Suzuki Vitara Cars & Trucks
Need spark plug wiring sequence, 1985 toyota corolla 1600 2 door hatchback, rear wheel drive
With the 2T-C, 3T-C, and 3K-C engines the Firing Order is 1-3-4-2
The distributor rotates ->Clockwise. (The rotor actually)
Number 1 spark plug tower on the distributor cap, faces directly towards the engine. Number 2 faces the back of the engine, Number 4 faces the front of the engine, Number 3 is to the outside away from the engine.
Number 1 spark plug is at the front of the engine. 1-2-3-4
With the 4A-C engine, and other A-Series, the Firing Order is 1-3-4-2
The distributor rotates ->CounterClockwise.
Number 1 spark plug tower is towards the engine, and faces the back of the engine. Number 3 spark plug tower is away from the engine, and faces the back of the engine.
Number 2 spark plug tower is towards the engine, and faces the front.
Number 3 spark plug tower is away from the engine, and faces the front.
Aug 16, 2009 | 1985 Toyota Corolla 2 Door
2 sets purple hdd rails missing
I'm sorry Patrick but there seems to be some confusion here. FixYa is a website where you ask questions concerning various products, and we try to answer them.
FixYa is not directly involved with any manufacturer, and does not do warranty work, or provide parts.
Jul 31, 2009 | Chieftec CX-01B-B-SL-OP Mid-Tower Case
Chieftech HPC-360-102 Power Supply dead
check the size of power supply most are a standard size some from propriety manufacturers are smaller. most are fitted top of case at the back and take up the space across the back about about
6inch wide 4 inch high 6inch deep if yours is this size its standard and most should fit get one that is rated at least 400 to 500 watts
ensure it has at least 6 4pin power sockets floppy power socket and the same motherboard sockets as your old one
Mar 10, 2008 | Chieftec (ADX-01GNDU/SPX-02GNF) ATX...
Chieftec Dragon Logo
618 people viewed this question
Top Chieftec Computers & Internet Experts
David Payne
David Payne
Are you a Chieftec Computer and Internet Expert? Answer questions, earn points and help others
