Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front loader model #GHW9400PW1 and the code i get is an H then an F. does anyone know what this could be?
5 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: replace the bellow in my front loader whirlpool washing machine
Hello. You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you. Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
Posted on Aug 18, 2009
SOURCE: Whirlpool Front Loader Washer Model# WFW9600
I had a suds error and then a F 35 error. Turns out I had a collection of junk and debris between the door seal and the drain at bottom of door. Cleared out the debris now my washer is running like a top. (washer senses pressure error, thats why I got said error codes)
Posted on Oct 19, 2009
  • 662 Answers
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
Posted on May 19, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a whirlpool front
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Posted on Jun 25, 2011
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won┬Ęt start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
I require a user's manual for a Whirlpool washing machine that is approximately 10 years old. I don't know the model but the serial no. is 34 9945 011318
with out model number you will not be able to get the manual, the model number is usually on lid/door rim ,inside the lid for top loaders and inside door for front loaders
IF ya find the model number go here and download the manual http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Aug 03, 2011 | Whirlpool Washing Machines
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need dial for f/loader . Whirlpool AWM6100.
can't seem to locate parts for that exact model number but check HERE
Aug 27, 2009 | Maytag PYE2300AY Electric Dryer
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
