its normal that pairing bluetoth need code, but dont worry you can insert code that you want, for example you insert code 1 at your phone for pairing insert 1 to at your pc ,it will work, the code you insert at phone must same as you insert at pc it will work
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
it should go like this menu/connections/bluetooth/paired devices/options/add new device (pair new device)/the BT will go ON tt will find new devices select one that you want to pair wait for the connection then it might ask you for some kind of code unless the other device is mobile from other user and he put some other code for himself than you will need to ask if not just type 0000 or 12345 everything is automatic and it should be easy - i dont know if that 100% accurate cos i sold mine n70 and now i have e51 but it should go as i said
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or
‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful
pairing, repeat steps 1 to 3.
switch on the bluetooth on both the device and then select option "shown to all "now starts searching from any one mobile.now you will see the name of other mobile ,now select option button and then it will ask you to pair..just select pair option and then it will ask you for a code type any code like 0 ,1 ,2 ,now other device will get a message that mobile no1 wants to connect .click on to accept and now it will ask you for a code, here you have to enter the code which you typed at mobile no1 .enter the code in mobile no2 and your mobiles will get paired
i tried my level best to resolve the issue.it was not my problem that i was not getting reply message from you........but anyway ...if you want further help let me know........i am still online to assist .........
thanks for using fixya technical support.you have a wonderful day
Pairing your Cell Phone to your Bluetooth Headset: (FROM Bluetooth Headset) 1.Make sure Bluetooth Headset is fully charged! 2.Hold down talk button (center button of headset) up to (Five) 5 seconds, then WAIT until you see a solid blue light then immediately flip open earpiece part of headset. THIS MEANS the HEADSET IS NOW IN PROGRAM MODE. AT THE SAME TIME/ WHILE BLUETOOTH IS STILL OPEN & IN PROGRAM MODE…. (FROM CELL PHONE)
1. Click on “Menu” (Left Button) 2. Scroll to Bluetooth icon. (Lower Right Hand side of menu) 3. Click “Ok” button 4. Then click on “My Devices” 5. Click “OK” again 6. Select “FIND NEW”: Cell phone searches/connects to pair up with Bluetooth Headset. 7. Once your Cell phone discovers your new headset, select “ADD” or click on the recently paired headset device. 8. You will then be prompted to enter a pairing code. Use either.. a.0000or b.1111 or c.9999 Congratulations on paring/ connecting your new Bluetooth Headset w/ to your new Cell phone!
