Question about Ovens
My panasonic microwave oven model #nnsw968w will not heat. It reverts to signal "H97". Is this a problem with it's "child lock" function?
  • richard_ob1 Nov 02, 2010
    advice well given. I agree that this microwave is faulty.
  • Ovens Master
  • 11,800 Answers
No, the H97 error code signals the fact that the inverter board - the board that supplies the power to the magnetron (the part that produces the microwaves) - has failed. This is a hardware fault, and a critical one: no inverter = no high tension = the magnetron can't work = no microwaves = no heat.
Since the inverter produces very high tension - over 5000 volts - when it fails it fails completely - the board can't be repaired and will have to be replaced.
Since the high tension can easily spark if you get near the capacitors on the inverter board (they remain constantly charged, whatever happens to the rest of the board) and the spark will kill you instantly , you should not even get near to it, leave this repair to well protected professional. It will cost you around $150 so you should think very carefully if it's worth repairing.
Personally i wouldn't trust an oven that has suffered such a severe failure.
Posted on Nov 02, 2010
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 | Ovens
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How do I remove the child lock message on my Panasonic Inverter Microwave?
    Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
    Aug 20, 2011 | Ovens
    I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
    Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
    http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
    Good luck :)
    May 04, 2011 | Ovens
    Electrolux EOC68000X oven Demo mode only
    If that model number EOC68000X is correct then in the manuals I have for that Model there is no Demo mode setting.If you can supply the PNC number then I will investigate further.Try relogging your call with this information.
    Hope this helps.
    Jun 06, 2010 | Ovens
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Kenmore oven locked
    Hello dktshopping,
    I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
    Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    97 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
