Question about Motorola Mobility RAZR V3
Zapped screen small magnet were put on the back of my razor to mount for a hand free set device I bought and now the screen is haywire is there anything I can do you get it back.... everything else on the phone works fine?
    Guru:
  • 859 Answers
Hello Cowgirl,
Sorry to say this and frankly please don't rate this as anything other than fixed or don't rate it all since I can only give you news you probably already have sensed through intuition.
Anything magnetic should be kept as far away from computerized devices as possible.
Frankly, I surprised that only your screen is affected. You got lucky that way actually since you can still use the phone to call and receive at least.
I won't go into the physics on how screens work on cell phones but suffice it to say they're sensitive to magnetism due to the physics involved.
If you have insurance you can get it replaced for $50. Otherwise you will have to take it in to a phone store operated by your provider. They will probably give you a loaner phone while its in for repairs unless you choose to upgrade into something new.
Sorry again, its not what you wanted to hear, put if you rate this rate this as fixed please since its the only answer. Otherwise, please don't rate it at all.
Sorry again to be the bearer, etc. Good luck.
Worldvet
Posted on Jun 13, 2008
How do i disassemble my Samsung Galaxy Rush
Check you tube for that . They have all the others.
Jul 29, 2014 | Samsung Galaxy Rush Boost Mobile
How to remove magnets from sharp carousel microwave
If the oven has not run for a few minutes and is not plugged in, there is very little chance that the high voltage capacitor has any charge stored on it.
If you're still concerned about getting a zap that might make you get a cut when you pull back your hand on the sharp metal inside the microwave, you can discharge the capacitor. Here's how.
The magnets are in the magnetron.
Other questions? See the FAQ here.
Sep 05, 2012 | Sharp Microwave Ovens
Wrecking for magnets
Sep 05, 2012 | Sharp R-1610 Microwave Oven
How do i change plugs on my 2010 hyundai accent?
Pull one spark plug wire, replace that plug using a spark plug socket,vturning it counter clockwise, replace spark plug wire, and repeat until all of youre spark plugs are replaced.
May 22, 2011 | Hyundai Accent Cars & Trucks
The glass has come away from the outer hood at the
I have the same problem and read that in some cases 3M Wind-o-weld has been used to fix it. I tried that, and as soon as I put the top down and back up, it pulled back away. looks like I'll be getting a new top
Jul 20, 2010 | 2003 Audi A4 Cabriolet
I have a HC-1500 hedge trimmer tested the kill swithch and it tested good, thought it was a bad coil so put a new coil on, still has no spark, should I put on a new flywheel? One magnet on flywheel seems...
take it to local small engine shop and get a free estament from them
they will tell you whats wrong with the unit
also have you tried to hold the coil wire and have a friend pull it over ??
if you get zapped then try replacing the spark plug
Aug 04, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Have small picure in upper right hand corner, but not full screen
due to some magnet
try putting a less powerful magnet near it
sometimes will be removed
Jun 19, 2009 | Philips Magnavox 20MC4304 20 in....
My lg incite bluetooth does not detect the motorola S9 bluetooth
this took me nearly an hour to figure out, but here goes:
go to "settings icon" - tap "bluetooth" - turn it on - go to "accessibility" tab - make sure your phone has a "name" - then make sure "allow other devices to connect", "all devices" and "other devices can discover me" are selected - then go back to the "general" tab - tap on the "bluetooth manager" link - go to "active connections tab" - click on "menu" at the bottom right corner - click on "paired devices" when the menu comes up - click on "add".
Now quickly put your bluetooth headset into pairing mode and as soon as the device and passkey asking screen comes up, tap on the little windows "find" (or "search") icon next to the "device" field. once your phone detects your headset, it will take you back the device and passkey screen, where the name of your headset will now appear in the device field. all you have to do is input your device passkey.
Now go back to "bluetooth manager" screen, where in your "my shortcuts" tab, your "hands-free connection" icon should be present. if it's not, then click on "new" in the bottom left corner and select the "hands-free/headset setup". On the screen that comes up, select "next" which will take you to the next screen. Here your headset device icon will be present with a small red checkmark beside it. Tap this and your phone will establish a connection with your headset. It will then take you back to "bluetooth manager" - "my shortcuts" screen where your "hands-free connection" icon will now be green with two small arrows beside it pointing towards each other. If you click on the active connections tab, you'll see your headset device icon there. Also, a pair of headphones will pop up on your windows toolbar at the very top.
After this setup, to ensure your phone's security, go back to the "settings" - "bluetooth" - "accessibility" tab. Select "paired devices only" under the Accessibility heading, and deselect "other devices can discover me".
Hope this helps everyone...so far this is the only non-user friendly feature of the phone that I've come across, rest is pretty good and highly customizable.
Mar 20, 2009 | LG Incite Cell Phone
HANDS FREE 6300
How many `paired devices` have you got in your connectivity settings.
Delete them all and search for a new device e.g: your bluetooth headset.
Best luck
Jan 17, 2009 | Nokia 6300 Cellular Phone
Crankshaft Sensor
what ever u mounted fom the old flywheel was not a magnet....the magnet is internal to the cranksensor and the flywheel slots trigger the sensor....whatever you attached maybe causing this code
Oct 14, 2008 | 1998 Dodge Ram 1500 4WD
Motorola Mobility RAZR V3 Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
