Question about HP Officejet 7130 All-In-One InkJet Printer
My printer sat for anout a year. Turned it on and it said supply expired. replaced the ink. Removed the battery and put it back. That message went away. Now it says close print door. It is closed. Any suggestions?
  • 43 Answers
Hmmm, how long did you leave the battery out. One time I had to leave it out about 1 hour. That worked for me.
Worth a shot, also check to make sure that the carriage is in it's proper place. Open the maint. door like you are going to change the ink, check to make sure all seated properly, close cover and see if error goes away. Also try unpluggin from power and plug back in.
Posted on Nov 02, 2010
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
7110 supply expired
According to posts on a another forum, you can fix this problem by unplugging the printer, removing the battery or sticking a business card between the battery and its contact point. It should work when you plug it back in.
Jun 15, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Expired HP printer cartridges
I have the identical problem with an HP Business Inkjet 1100.
Once cartridges were past date, the printer would no longer print from Windows XP. It would however work perfectly from Linux.
I did not find an ini file as mentioned in other posts, and I really did not want to open the printer as it worked fine in Linux.
The following fixed the problem:
1) Click on Start button, run
2) Type in regedit, enter
3) Navigate to HKLM/software/Hewlett-Packard/HP Printers/HPWH Toolbox/Common
4) In the right panel, right click on Ink, pick modify
5) Change 0100 to 0000
6) Save and reboot
Jun 13, 2007 | HP cp1700 Color Inkjet Printer
Printer
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left at front. No need to take it out, slip a strip of plastic like an old credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power down) with the battery insulated. Power up - Power down, remove insulator power up. Eureka!
Jan 24, 2007 | HP Officejet 7130 All-In-One InkJet...
HP Officejet 7130 All-In-One InkJet Printer Logo
116 people viewed this question
Clive
Clive
