Question about Hitachi 1TB External USB 2.0 Hard Drive
My Hitachi 1000 XL sleeps and disconnects and disappears del sistema, doing nothing!!
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
Testimonial: "My problem is resolv"
My singer XL 1000 Computer sistem the triming sistema is ON olld the time show can I do please.
The thread trimmer is on? Try pushing the button again. You've got two on this machine -- one for backtack and cut, and one just for cut.
Do you have the workbook? http://www.singerco.com/uploads/download/152_xl1000_wkbk.pdf
May 22, 2014 | Sewing Machines
Varadero 2008 no para de parpadear la luz del abs @
Hola, An?nimo para este escenario, necesitar?s el manual de servicio, la ficha de piezas y el manual del propietario si no puedes encontrar la mejor herramienta que hayas comprado para tu Honda, no desesperes, por tan solo cero $ 0 puedes descargar otra. Para obtener m?s informaci?n acerca de su problema y las valiosas descargas "GRATUITAS" que necesitar? para ver o imprimir, haga clic en los enlaces azules a continuaci?n. Buena suerte y que tengas un d?a maravilloso. Abs light flashing traction control turns on
ABS light flashing
Honda Varadero MK1 XL 1000 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
https://tosfauclimti.files.wordpress.com/2015/07/honda-varadero-xl-1000-owners-manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2012 | 2008 Honda XL 1000 V Varadero
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Apr 04, 2011 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
My Dell Latitude E6400 do not detect the Hitachi XL 1000 external disc
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
4. the drive may not be supported by the motherboard for your PC.
5. check the user manual for you PC to see if it is compatible with your device.
Mar 18, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
No puedo descargar la instalacion de ma lifecam microsoft vx-1000
aqu? est? el enlace, despl?cese hacia abajo a 1 Seleccione el tipo de producto, webcam, 2 Seleccione su producto LifeCam VX 1000, 3 Seleccione el sistema operativo, 4 Seleccione el idioma del sistema operativo, a continuaci?n, haga clic en Ir, la p?gina siguiente, haga clic en el primero en la arriba
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
Oct 15, 2010 | Microsoft LifeCam VX-1000 Webcam
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
CD RESTORE DELL DIMENSION 1100
La mejor manera de hacer esto es reinstalar el sistema operativo entero del rasguño. No hay restablecimiento de la PC para este sistema ni pudo ser dañado muy probablemente ya si usted tenía uno. Para probar, presionar ALT+F11 cuando usted enciende la computadora en la insignia del dell. Si esto no trabaja, usted necesitará insertar el CD de la reinstalación de Windows en la impulsión y cambiar formato su sistema entero y comenzar del rasguño. Después eso. usted necesitará instalar los conductores y las utilidades para el sistema del dimensiono.
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Hitachi 1TB External USB 2.0 Hard Drive Logo
774 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Fotis Papastamatiou
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
