Back to:
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Husquvarna Sewing Machine
posted by Miss Mopp on Jun 12, 2008
The feed dog button does not seem to be connected to the feed dog.  When I try to get the feed dog up, nothing happens.  Any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 20, 2008
Not Rated (0)
RickE1
Rank:Guru Guru
Rating: 92%, 49 votes
Here is your problem and how to fix it...
Look under your machine. Follow the shaft from your feed dog button to a bullet shaped pin that goes through a hole. It needs cleaning and oiling and freeing up. Its frozen from non-use and the oil is hard. Free this up, WD-40 or just a good dowsing with oil and tap it until it lets go. Just work it little by little. It will go.
Good luck.
Rick
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Husquvarna Sewing Machine:
I don't want to Accept this solution
Can you Help with these Sewing Machines problems?
Kenmore 15516 Mechanical Sewing Machine
I have an older Kenmore 17922 which hasn't been used in a...
Brother SE-270D Computerized Sewing Machine
What is the best thread to use on my new Brother Sewing...
Husqvarna Viking 1
I have a Viking husqvarna Sweden 60 20 and when i try to...
Brother Disney PE-400D Computerized Sewing...
Thread bunches on back of fabric after only a few...
Bernina Activa 140
My Bernina activa 145 S just stopped working. The light...
Loading problems.
Repair Service
Find Sewing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
