Question about Sony Playstation 3 (PS3) Console
Playstation turns on but TV says "no signal"
I can turn the playstation itself on... but the control does not connect and the TV does not show the main menu for the playstation.... any help?
  • thelordsgym Jun 13, 2008
    I just bought a Playstation 3 and hooked everything up. It will only power on with a blue and green light with a disc in it. It ejects the disc fine but will not display anything on the TV no matter which peripherial I connect it to. I have tried my other game systems and it works just fine with them. But the PS3 has no display. Any help, please!!!
  • 182 Answers
You could try the screen reset..... When the consoles in standby mode... press and hold the power button for over 5 seconds till you hear a diferent kind of beep and then it runs the optimal screen settings mode.. i hope this helps
Posted on Jun 13, 2008
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Playstation won't turn on just saying no signal
Hi, is the problem it wont turn on, or it not showing on tv?
if not showing on tv may be set for component instead of hdmi. If so you will have to use standard red yellow white connection to switch to hdmi in settings. hope this helped
Oct 31, 2012 | Video Game Consoles & Games
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
No signal
make sure the cable are set right if they are it could be your cables if your purchase the cables from bestbuy you can take them back open if that doesnt help then you need to send it back
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
No signal
turn off ,then turn on and try having the power button pressed for 5 secs to reset the video output...
Getting serious
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the menu. As far as your remote control, you need to connect it to your PS3 via the the USB port in order to sync the controller with your PS3, after this you can use it wirelessly. good luck!
Jun 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 and & DVD's
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Wont paly dvd's
Sony Playstation 3 (PS3) Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
