Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
When I plug the unit in, the fan turns very slow, and I smell fumes, but the unit does'nt turn on
  • 232 Answers
I am not able to give you a solution, but will put forth some possibilities for you to check.
  1. Spin the fan manually. No power, please. If the fan spins freely, and no grinding is heard or felt, then the starter capacitor or starter relay (whichever equipped) is defective. Internal capacitors are not serviceable. Replace the motor.
  2. If the fan does NOT spin freely and/or binds, either the rotor (air pump) is broken or a motor bearing is bad. The rotor is replaceable, the motor bearing is not serviceable.
If you decide to repair the heater as described then the air pump pressure must be reset, in either case, in order for the heater to burn properly. It is a simple process. Follow this link for instructions
http://www.reddyparts.com/pressure.htm
Posted on Nov 03, 2010
SOURCE:
Strong fumes from new frigidaire gas oven.what should i look for
If it smells like gas Shut the gas off outside call installer, or
gas company. If it doesn't smell like gas, most likely it's the "new smell" caused by the heat. If you have a kitchen vent fan turn it on. If it persists Call the installer or dealer. No action by them? call the mfg customer service number in your owner's manual. It's possible something was left in the oven burner area that shouldn't be there.
Feb 27, 2015 | Frigidaire Kitchen Ranges
I have a 1999 oldsmobile alero ... i'm smelling gas fumes as the car sits w a/c or heat on ..gas needle dosent work properly.. and humming noise...seems to smell strongest when low on gas..went t
For the first problem, if you can get me the codes I may be able to help you figure out the problem with the gas smell. The fuel gauge problem could be the gauge on the dash or the sending unit in the tank.
You should have the body computer scanned for trouble codes to find out whats going on with the ABS and traction control.
I have no clue on the humming noise.
Aug 09, 2012 | 1999 Oldsmobile Alero
Turns over well but is slow to fire off sometime. Can smell gas fumes inside the car as well as the outside. No black smoke from ehaust and no fuel leaks.
if you smell gas YOU DO have a fuel leak.... make sure your gas cap is good and or tight, also might want to look at your fuel pressure regulator.. the fuel system is pretty simple... let me know!
Jan 22, 2011 | 2003 Nissan Altima
Hello I own a 2004 Volvo and have fume smells
Most likely the catalytic converter temporary plugged and or the fresh air door jammed and allowed smell from the engine compartment came it. The catalytic converter can come loose and going around a turn it may plug it temporary and blow out the exhaust gaskets and cause the smell.
Nov 29, 2009 | 2004 Volvo S40
Smelling fumes from 4xl55. Also cycles many times b4 igniting.
Hi jim if you are smelling fumes turn it off and get a service done on it asap
Mar 27, 2009 | Dayton Gas Furnace Heater
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Heating & Cooling Logo
166 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
cavs1
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
