My Savin C2525 copier is showing a code SC443. It's FROZEN, some brainiac was trying to make counterfeit 50's. Can't get thru on any screen.
  • 3 more comments
  • marymichel Nov 03, 2010
    don't see service code 443 in manual. what is a fuser?
    My Savin C2525 is totally frozen and the code sc443 in on the display. Cannot get to any other screen all are frozen. It's a 2006 machine.
    wish it was as easy as unplugging.
  • marymichel Nov 04, 2010
    thought it was going to work but alas, no. It did shut down but came back with the same message. Also, a bit more detail, flasing "Cannot connetct with DHCP server".
    Any more suggestions. I cannot believe no one out there can figure this out! Come on man!
  • marymichel Nov 06, 2010
    tried but didnt' work
  • 904 Answers
Hi, you should be able to reset the machine to clear that error code. Turn the copier off using the orange switch on the lower left side, wait a couple of seconds for the green light on the operation panel to go off, then turn the copier back on. The code should be gone, and you should be able to resume normal operation.
The copiers do have built-in counterfeit detection so that they will lock up when someone tries to copy any denomination dollar bill. If you turn the copier back on and the SC443 error code is still there (or if it reappears when you try to run a copy) you may need to have either the image transfer unit (part# B223 6036) or the image transfer motor (part# AX05 0249) replaced by a service technician, or the technician might have to clear the machine's non-volatile memory. But more than likely, once you completely reset the copier, it will run fine again.
Posted on Nov 29, 2010
  • 666 Answers
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Posted on Nov 07, 2010
  • 17,970 Answers
Maybe you damaged the encoder disk during your repair on the transfer unit, or you did not install the yellow transfer roller the right way. This SC has something to do with the belt rotation.
It is very easy to damage the belts when they are taken apart. Best and easiest thing is to just order a new transfer belt assy'.
Hope helps.
Posted on Nov 05, 2010
    Genius:
  • 1,456 Answers
Hello
You will have to reset your machine
Press and hold the "./*" key and the "#" at the same time. Hold down both of these keys for at least 10 seconds.
Release the keys when the copier shuts down. The copier will shut down and automatically power back up. When it has completed the power cycle, it will have been reset to the original settings.
You may lose all saved data on the copier
Posted on Nov 04, 2010
    Brigadier General:
  • 5,158 Answers
Unplug it for about ten minutes. that should reset it.
Posted on Nov 03, 2010
  • 2,299 Answers
I am sure that this has been suggested already but just in case it hasn't. Try unplugging the maching for about 15-20 minutes. Then plug it back in and see if it clears.
  • 2,427 Answers
The service code 443 is a bit strange to me,, did you check your manual for the error / service code list and see what it is.. more than likely its a consumable and the once I'm thinking is the fuser. You might need to replace your fuser..
Posted on Nov 02, 2010
  • Rishi Roshan Ali Nov 05, 2010
    the fuser is the device that binds the toner to the paper.. Its what gets Hot, look at your manual for instructions on replacing..
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
SC672
do not know the language post in english
Jun 26, 2014 | Savin Toner C3030, C2525
Im getting magenta backround on all color copies. I replaced the drum and developer, this did not change the problem
I had the same issue. I removed all the drums and DV units, removed the transfer belt and open the manual infrrd door and pulled to fuser. I found huge piles of magenta tone all over the place. Cleaned it up, put it back together and runs like a champ
Feb 08, 2013 | Savin Transfer Belt for C4540, C3535,...
Restoring default setting on my savin c2525
in user tools, hold the # key and press either, system setting or copier settings
Aug 14, 2012 | Savin Office Equipment & Supplies
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Code programming
Hi There,
The max on that model is 50. You can take out the ones that you no longer use to make more space. That is the only way.
Thanks,
Steve C.
Please rate me....Thanks.
343 people viewed this question
k24674
Marvin
Marvin
