Question about Prestige Remote Start
It starts and runs, than shuts off 3 seconds later? i havent tried anything yet, and it was installed in 2002. jeep grand cherokee.
  • 3 Answers
Do you have anti-theft system bypass module installed? Transponder key bypass? Try unlocking the doors with your factory Jeep remote (turns off alarm) and leaving the gray transponder key in the ignition cylinder. Then try activating your remote start. Sounds like one of the factory anti-theft systems is still active. Basically if the car's computer doesn't want it to run, the car won't run. You have to fool the car into thinking it is OK to start and stay running without the key and anti-theft device deactivated. You need to leave a transponder key in the vehicle under the dash to bypass that system. You can get a generic one for about $20. You MUST have 2 original gray transponder keys in order to program a third. There is a sequence of putting one key in the ignition, then the second, then the new blank key so the cars computer knows to allow that key also. If you do not have 2 original keys, then you need to go to someone that can program properly like dealership or some locksmiths or alarm shops. Then they usually charge about $100 for a second key. You don't have to have the key cut. That way if someone finds the spare transponder key in the vehicle, it wont turn the ignition cylinder. The anti-theft bypass module (factory alarm bypass) runs about $25. Bulldog Security or JBS model 791 should work for your vehicle. If you live in an area where car thefts are common, you may not want to bypass these factory security measures.
Hope this information helps.
Posted on Dec 11, 2010
WHY MY 2002 JEEP CHEROKEE GRAND WONT START THERE IS A RED CIRCLE AROUND A KEY AND A FLASHING LIGHT WHAT TO DO ?
lost the operators guide I see, like all post here ,same topic.
the dash warning are unique to all cars, all years, and all options.
sounds like you have SKIM, option ,
the operators guide said.
try both keys, car came with 2, lost that too> the spare fob set?
there are 2 lamps SKIS and SKIM.
the key logo means this :
the key transponder chip is bad in THIS key , try the other.
there are no batteries in the key, for this.
the battery fob only runs door lock, logic.
never run any jeep 1999 to now with only 1 key
use 3 keys, so you can make your own spares.
or pay big money later... for sure.
Oct 10, 2014 | 2002 Jeep Grand Cherokee
My jeep 2002 cherokee dosnt start right away , it takes about 2-3 times till it starts
have about three customers with the same problem and i havent managed to solve it as yet,so if find the answer please let me know .
May 16, 2010 | 2002 Jeep Grand Cherokee
Diagnostics "P1762 Manufac. Contrl. Transmission"
Had the same code on my 2002 Jeep Grand Cherokee. Started having shifting problems as well. Code is for governor pressure sensor on trans. Cost me about $800 for dealer to fix. No problems after part changed out.
May 22, 2009 | 2002 Jeep Grand Cherokee
Jeep will not start after being shut down
If you installed a stero system make sure the amp is not on all the time. Other than that try testing the starter and components.
Apr 09, 2009 | 2002 Jeep Grand Cherokee
Auto start will start car then turn car off 3 or 4 sec later.
on most remote start application a wire is installed in motor with one wire on the fuel injectors that wire reads rpm if its to high it stalls if to low stall so check wire get back to me
Dec 27, 2008 | 1998 Jeep Cherokee
1996 Jeep Grand Cherokee - Will Not Start or Run
they have crankshaft sencers on the transmission on jeeps. it would be up high on the drivers side on front of transmission. they will cause it to not get fuel or fire and can run then quit.
Jul 19, 2008 | 1996 Jeep Grand Cherokee
Prestige Remote Start Logo
811 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
