Can't get my new t10 to be recognised by the samsing media software or by Windows media player to be able to sync and transfer files
Software installs fine form disc but just wont let the device 'in'?
Why is this?
Heres how I solved this problem
- I was running XP SP2 with WMP10
(Windows Media Player 10)
- Windows will not recognise the T10 unless it has the right MTP (Media transfer Proticol) drivers. This is the little yellow flag you may see on the task bar adter Windows detects the device and trys to install the driver. The drivers are only found in WMP11. Therefore unless you are running WMP 11 your T10 won't sinc or be recognised.
- The Samsung software wont help- so don't bother even installing it as WMP11 has the drivers and does everything the Samsung software does + more.
- I tried to download and install WMP11 directly from the microsoft website but my PC failed the authentcation so I saved the file to my HD instead.
-I then unpacked the WMP11.exe file using WinRAR which i downloaded for free from http://www.download.com/WinRAR/3000-2250_4-10745708.html.
- I individually ran the WMP11 install file and then all of the other unpacked files by double clicking on them (it takes some time). This installed WMP 11
- I then shut down the PC, plugged in My T10 and WMP/windows recognised the T10!
I had a friend who alos did the above but had a couple of problems- he uninstalled WMP10, Installed WMP11 using the WinRAR method above and it didn't work. After uninstalling WMP11 and then reinstalling it again using the WinRAR to un pack it it finally worked after a couple of re boots.
Note: Prior to using the above method i googled and tried several other ways to get the T10 recognised and none worked. From what I can tell you Need WMP 11
Hope this helps
Old discussion but I had the same problem:
Computer with xp sp3 wouldnt recognise t10. Not sure if all these sequence of events are necessary but I managed to get it working by:
Solution: use Linux!
I too cannot connect this device using WinXP SP3. There does not seem to be a solution for this OS. If I had known that the T10 was not a standard USB mass-storage device (like a memory stick) I would never have bought it.
Fortunately, I am able to connect it to my Linux machine and mount it easily using mtpfs, which is an implementation of the MTP file system, and then manage the files on the device just as if it were another hard drive.
There is no solution to this issue. If you can, roll back WMP11 to WMP10. If you are using windows XP SP 3 you are out of luck. The T10 depends on MTP drivers which are rolled out by Windows via WMP. The newest versions do not work with the player (my guess is the player incorrectly implements the driver and is now broken).
I have been fighting with Samsung over this matter for 3 weeks now. They told me I am out of luck - they cannot guarantee compatability with future versions of WMP or Windows. I was told to call microsoft and then hung up on.
I would suggest that if you can get a refund on the product do so - and avoid buying Samsung products - specifically in Canada. They're support process has been awful - insulting - and useless. Samsung US was somewhat better.
I contacted Samsung and they said to delete Itunes because it blocks the Samsung T10. This didn't work but I restored m PC back to before I restored Itunes and it worked perfectly. Maybe This will help
This is absolutely ridiculous!!!
This is one of hundreds of forums on how to connect a brand new samsung model phone to your pc! It is not the search for a magnetic monopole!
I have a half major in computer science and fortunately understand most of the instructions and problems mentioned above but if my parents or plenty of other techno idiot friends of mine were to try the same thing they'd be screwed!
I will try the stuff above and enter the third hour of trying to get a music file onto my phone. Frankly I'm disappointed in samsung and think they should be ashamed of themselves! If the the phone has compatibility issues sort them out don't put out a piece of **** phone with a software cd that just doesn't work!!!
Install Vista or Windows 7 RC1. It just plugs in and works perfectly.
You need MTP Media Transfer Protocol drivers. If you find them let me know where
I cant communicate T10 with my PC
im using XP as OS in my PC
I amrunning WMP11 on XP SP2 (as required). When I connect the T10, windows dectects new hardware and then goes insearch of the driver-but it showing into the device Manager with yellomarck ,no joy- it just gives up!!
kindly helpme out this problem.
SOURCE: Samsung YP-T10 MP3 player MTP problem
Something worth a shot is to add the device manually through controlpanel. You can select add hardware and follow the on screeninstructions.
great for beginners
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
http://forums.sandisk.com/sansa/board?board.id=announcements
SOURCE: YP-T10 will not connect
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
your problem will now soved
SOURCE: my Samsung yp t10 is not recognised by my pc.
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=YP-T10&prd_ia_sub_class_cd=P
I hope this information helps you out..
I purchased a T10 and installed the media player from the disc provided. I managed to transfer 1 MP3 disc but cannot get the media player to even read the second one. There is data on the disc as I can see it through Explorer. The programme appears to lock up my computer and even when I try to quit the programme it will not respond. The only solution is to switch off my PC and reboot
yes, I have the same problem. My PC won't recognise the player. I've spent hours trying to find a way but eventually gave up and bought a Creative Zen player for £19.99 which works perfectly and does more than the samsung. Samsung were most unhelpful when I contacted them.
I have a similar problem.
I amrunning WMP11 on XP SP2 (as required). When I connect the T10, windows dectects new hardware and then goes insearch of the driver-but with no joy- it just gives up!!
WMP cannot sync and wont even detect the device
Crazy!
I have windows XP system, n my USB port can detect pendrive and I also transfer data from my cell phone also. But when I connect Samsung T10 player, PC can't recognize it.Please suggest any solution for this.
My PC did not recognize my Samsung t10, but with my fone or other MP3 player can recognize and sync music no problem . I have tried everything for days now. It very frustrating.
