Question about Acer AL1916W 19" LCD Monitor
Distortion of digital photos.
When I try to display digital photos, they are distorted in a sense that it makes objects and people look slightly shorter and wider. It was suggested before that I change the aspect ration to 1440 by 990. However, on the sliding scale the "Lesser" side is 800 x 600 and the "More" side is 1280 by 1024. There is no setting for 1440 x 990.
  • 114 Answers
Try something bigger than 1440x990 if avaliable. (e.g. 1900x1600)
Posted on Jun 12, 2008
  • 55 Answers
I don't know what system you have your monitor connected to, but most of the older video cards don't support 1440 by 990 resolution and you would not be able to produce a good sharp image with older cards either. You can play with the settings on your video card to find the most acceptable resolution, but you might need a better and newer video card.
Good Luck!!!
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
If the master output lights go above green (into yellow) the sound becomes slightly distorted even at low speaker levels. i have cleaned the output jacks but it is still distorted
Does the distortion ALSO appear when you listen with headphones? If not, the problem may be downstream. The driver for the mute control line to the mute transistors may have a problem. Make sure the mute is off.
Nov 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
Aug 03, 2009 | Computers & Internet
Colours are getting out of sync, picture distortion
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 29, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Distortion
Have you selected the correct horizontal AND vertical resolution for the screen. PC's sometimes don't automatically select them correctly
Jul 18, 2017 | E-Machines E17T 17" Flat Panel LCD Monitor
Settings
you will want to turn your radio volume up till you hear distortion then trun it down slightly. then turn your amp up until you hear distortion then trun you amp down slightly.
Aug 06, 2008 | Alphasonik PMA600HC Car Audio Amplifier
Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Jun 09, 2008 | Acer AL1916W 19" LCD Monitor
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Acer AL1916W 19" LCD Monitor Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
