Minolta cspro ep2010
Dear experts
Minolta copier
Model: CSPRO EP2010
Warning panel shows the lower door on the right side is open, even though that door is shut closed and is not open. The copier does not operate.
  • vbsqlCoder Jun 16, 2008
    Wiz Cogz,
    Thanks for the tip! My Minolta copier, Model: CSPRO CP2010, has only two front paper trays. But listen! It's not warning about the bottom door (paper tray) in the front that's open. The warning panel shows the bottom door on the RIGHT SIDE of the copier is open even though that bottom door on the RIGHT SIDE is closed shut. Bcause of the warning light, the copier does not operate.
    Thanks again
    vbsqlCoder
    Orig. Problem Description:
    Minolta copier, Model: CSPRO EP2010
  • Anonymous Mar 17, 2014
    minolta di351f shows duplex door open but it is closed
  • 1,326 Answers
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Posted on Jun 13, 2008
Code d'erreur C0F10 de photocopie Minolta cspro ep5000
Remove the Large glass below it you will see a pulley in the middle to the right of the pulley you will see a lens assy. off to the right of the lens assy. (looking from the left side of the copier) near the front side of the lens assy. is a small sensor the monitors the Exposure lamp. that sensor is causing that code. Open close front door to reset. if it comes back replace the sensor will be hard to fine due to the copier is a legacy machine from Minolta now Konica Minolta. try link below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 10, 2014 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP2010 CSPro copier: Where does the develper bottle go??? I see the Toner MT 102a bottle but where does the Develper bottle install. Or does the toner bottle already have the develper filings?
When the developer is added during normal replacement, the developer bottle is installed in place of the toner bottle. Then when the F8 mode is initiated from the service mode the developer is added into the developer unit and automatically calibrated. This is only done after the old developer has been cleaned from the DV unit.
The toner bottle contains no developer. The developer is replaced separately and only needs to be changed about every 80,000 pages.
Good Luck and Thnak You for using Fixya.
Sep 21, 2010 | Minolta Office Equipment & Supplies
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Drawer error
on the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Aug 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
346 people viewed this question
jasbo
jasbo
