Question about Philips Senseo Cappuccino Coffee Pods, 10-Count Packages (Pack of 4)
I cannot find Senseo Cappuccino pods available anywhere online, not even at Senseo website. Has this been discontinued?
4 Suggested Answers
  • 2976 Answers
SOURCE: coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Posted on Jul 26, 2009
SOURCE: We have a Philips Senseo
senseo now makes pods in many coffee flavors and coffee varities
can be bought via internet
Posted on Nov 16, 2009
  • 3 Answers
SOURCE: philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Posted on Apr 07, 2010
Senseo 7860 leaks
maybe you can see more at the Philips website
7860 leaks... where????? SENSEO Coffee pod system HD7850 60 Latte Select
Jan 19, 2014 | Philips Senseo HD-7810 Coffee Maker
Where can I buy some Senseo coffee pods?
Senseo coffee pods are available in a variety of locations both locally and online. If you prefer something local, try Wal-Mart. Otherwise, I have compiled a short list of some online options for you to order from.
http://www.senseo.com/
http://www.ebay.com/sch/i.html?_nkw=senseo+coffee+pods
http://www.coffeepodshop.co.uk/Senseo-coffee-pods-c-253.html
Feb 07, 2013 | Wine & Spirits
Philips senseo coffee is watery
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
My senseo machine doesn't seem to produce the crema layers even though i've followed all the instruction
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Oct 06, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee tastes stale even after cleaning
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
My philips senseo new generation won't open I suspect a vacuum-problem but don't know how to solve this can you advise me?
Eureka! I have solved this problem.
Disconnect your Senseo from the power. Take it to the sink. Hold it upside down and put hot water in the coffee outled. In less than 30 seconds the senseo will open.
The problem with Senseo is that - especially with coffee holders for 2 cups and chocolate - after making the coffee, the pod holder and the pod cool down. This creates an underpressure, that prevents you opening the Senseo. Hot water will increase the pressure and then you can open the senseo very soon.
This solution was found in despair after struggling with all the complex tool involving (knives, pumps, etc.)
Let me know if it works for you
Hans Beers (hansbeers@zonnet.nl).
Mar 26, 2009 | Philips Coffee Makers & Espresso Machines
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo Cappuccino Coffee Pods, 10-Count Packages (Pack of 4) Logo
4,664 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Deanna Melroy
Deanna Melroy
Level 1 Expert
Kolbrun...
Steve Allison
Steve Allison
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
