Question about Stairmaster Stepmill 7000 Pt
I have a StepMill 7000 PT that has a problem of gaining speed. It's as though it doesn't have a clutch or brake. Is it the circuit board or alternator? Jerry Whetstone JWhetstone@altoona-iowa.com
  • Stairmaster Master
  • 918 Answers
This video covers the electronic troubleshooting for a complaint of No Resistance on the Stairmaster Stepmill 916.Tools Needed: Multi Meter, Assistant for Testing Purposes
It is necessary to begin by removing the user's right side cover to gain access to lower control board and alternator for testing purposes.
  • Using your multi meter on the volts setting, you will place your black meter lead to the Ground test point on the lower board and place your red meter lead into the back of the cable connector where the brown wire is located. Have your assistant step onto the steps. Voltage should be present. If no voltage is present, check all cables. If cables check out, the console should be replaced. If voltage was present, it is time to move to the next test point.
  • Place your black meter lead to the Ground test point and the red meter lead to the Tach test point. Have your assistant step onto the steps. Voltage should be present. If no voltage is present, the alternator brushes should be replaced. If voltage was present, it is time to move to the next test point.
  • Next component to test for a no resistance issue is the load resistor. You will be testing for .5 -.7 ohms. Place the red meter lead to the white wire connected to the load resistor and the black meter lead to the black wire. If the proper value is not found when the load resistor is tested, it should be replaced.
You have now tested the entire electrical circuit. If the problem still exists, you have a mechanical failure or you should verify the results of your testing.
Troubleshooting Video for No Resistance on Stairmaster Stepmill SM916
Posted on May 21, 2014
2 Suggested Answers
  • 49 Answers
SOURCE: stepmill 7000 wont regulate speed
Check the blue wire to the alternator. Check all connections. the blue wire is the tach wire. no tach signal and you cant climb fast enough!
Posted on Sep 01, 2009
On idle machine -- power and field lights are lit, relay is NOT (relay board)
With everything that you have tested and the relay board testing okay, this sounds like the console is the problem.
Jan 02, 2014 | Stairmaster Stepmill 7000 Pt
Stepmill 7000 PT cs com error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is a communication error. Start by confirming continuity in the wiring harness. The following link will show how to use a multimeter.
Video about Multimeter Testing
Nov 21, 2013 | Stairmaster Stepmill 7000 Pt
Stairs won't speed up or slow down
You should start by verifying that your relay board is functioning properly. The following videos will help you through the troubleshooting of this issue.
Nov 15, 2013 | Stairmaster Stepmill 7000 Pt
Cant find the + or , to change language on the 7000 pt climber
The + is the same button that you use to change the step level up and the - is the button for step level down.
Jan 05, 2013 | Stairmaster Stepmill 7000 Pt
Stepmill has no resistance when starting
First thing you'll want to do is check the alternator brushes. Here's a link to the different types offered for the Stairmaster 7000PT:
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
If the brushes look like they are in good condition you can also test the relay board. This link will take you to the procedures for checking the relay board:
Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
Nov 06, 2012 | Stairmaster Stepmill 7000 Pt
My stepmill has no resistance on the steps. It goes full speed with out turning it on a program
you prob have bad alt. brushes. on the back of the alt. there is a small access panel where the brushes are located. they wear out over time and need to be replaced every yr or so
Aug 19, 2011 | Stairmaster Stepmill 7000 Pt
I have problem with master console of step mill 7000 pt stair master
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable.
Stairmaster Stepmill 7000PT Console Upgrade
C40 Console Repair Video for Stairmaster Steppers
Oct 19, 2010 | Stairmaster Stepmill 7000 Pt
7000 PT will not start up (display flashes)
On that relay board their should be 2 lights engaged:
1.power 2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
Feb 11, 2010 | Stairmaster Stepmill 7000 Pt
Stairmaster Stepmill 7000 Pt Logo
161 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
fordexpert
Craig Butler
Craig Butler
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
