Question about NetGear RangeMax NEXT WNR834B Wireless Router
What do I do with my Netgear WNR834Bv2 router? It does not show the blue wireless connection light on the front panel - even though I already did a hard reset. I am connecting it to a Huawei B200 wireless gateway. Will the combination work?
  • NetGear Master
  • 7,733 Answers
Go NETGEAR Router and configure.
Posted on Nov 03, 2010
  • zero02_mmx Nov 06, 2010
    Got the issue sorted out. The internal WiFI card was removed from its base and connection, that's why the blue light does not appear...
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried...
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
Feb 06, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Netgear WNR834Bv2 failed - powerlight is off, but all other lights are on solidly incl the router and wireless lights (the latter solid, not blinking) and all four ethernet port lights, despite nothing...
If you haven't tried using the reset button, should be an explanation how to use it on the router in the manual, try that.
Also, try a replacement power supply to the router, if you can get hold of one. As this maybe faulty.
However, likely faulty router, maybe due to power surge, due to lightning/bad weather.
Jan 24, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I'm unable to see the SSID Broadcast on WNR834Bv2 even though it's enabled. I've tried rebooting, resetting the router, Turning SSID on or off, nothing. All the lights are in the right place, and only...
Are BOTH the top two boxes ticked under "advanced wireless settings" ?
Having a name in the basic wireless settings box does not mean it cannot be hidden I have my SSID set under basic but hidden under advanced this is a small security measure on my part.
Aug 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
No Power to my Netgear Rangemax Next Wireless N-Router WNR834Bv2
This happens from time to time with these routers. It happenned to me with a Linksys and I found that the power unit in the router failed. One thing you could do is try a couple of different wall sockets or see if another adapter might work. Is your Netgear new enough to get replaced by the store?
Jul 08, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear wireless router keeps asking for password do not have one
Login is admin and password is password are the defaults for this router.
Oct 30, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Connection
I can't promise this will help but I can tell you it was the solution for me, I do however have the WNR834Bv2 router.
My lan setup consists of a win2k fil/print/sql server, two boxes in my kids room(wireless), two pcs in my bedroom(wired), and one old laptop in the living room(wireless).
Out of the blue one day the lan connectivity on the wireless machines became incredibly slow and in some cases died completely.  Rebooting would sometimes get a re-connect, sometimes not.   The wired machines were completely fine however.
After much research, the first solution *appeared* to be a master browser issue.  Basically you turn off the computer browser service on all machines which are not designated the master browser.  Research master browser for more detailed information.
I saw an immediate increase in network speed after applying this change to all machines, but not soon after, connection/speed problems returned.
In retrospect, I believe this happened because as part of my attempt at fixing the problem as a whole, I upgraded my firmware for the router to the latest version:  http://kbserver.netgear.com/products/wnr834bv2.asp#
I say this, because once I decided to revert the firmware to the version it came with as a test, my connection and speed problems completely disappeared, and I have had no problems since.
Aug 16, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Stupid router
SUE NETGEAR PURPOSE OF WIRELSS ADAPTER IS TO CONNECT WIRELESSLY, IDIOTS
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
241 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
