Question about Whirlpool Dryers
Gas Dryer isn't producing heat. - Whirlpool Dryers
  • Teaseshirts Jun 17, 2008
    What's up with the advertisement open.in? Very inappropriate.
    Problem Solver:
  • 14 Answers
Is the gas turned on??? the inlet valve is a double redundant syatem so it can't stay open.in emergency .replace if it wont open on demand..... check thermostat.. clean out all the lint in the cabinet so it can breath and won't catch fire.
Posted on Jun 13, 2008
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
The drying light is flashing and the dryer isn't heating up
heatman101[]\==-
Jun 26, 2011 | LG DLE2514 Electric Dryer
All of a sudden, my 18 year old Kenmore gas dryer is not producing hot air. The motor is working & the barrel is revolving. What can I do short of spending $500-$600 for a new comparable Kenmore gas...
It sounds like your heating element has given up the ghost and broken OR you have a bad thermostat that isn't telling the heating element to work. I would suggest you find the tag on your dryer with the model number on it and then go to www.searsparts.com and look it up and find the heating element and thermostat and decide if you want to spend that much.
NOTE: Usually, on older models, I always recommend that my client replace both so that I don't have to come back again in a few months to change the other. They seem to both fail close to each other.
Jun 18, 2011 | Kenmore Dryers
Cabrio Electric Dryer isn't heating up
heatman101
May 29, 2011 | Whirlpool WED6200S Electric Dryer
My 73942 gas dryer isn't producing heat. What should I do??
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 16, 2010 | Kenmore 73952 Gas Dryer
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
Dryer turns, but there is no heat being produced
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 06, 2010 | Whirlpool WGD5800S Dryer
Not enough heat is produced from the dryer
heatman101
May 13, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
