Question about Lenovo 3000 N100 0689 Notebook
Will not boot up or turn on though it is getting power
Laptop shut down, when battery ran out., went to black screen. Plugged in AC but will not boot when pressing the power key.
  • Anonymous Mar 26, 2014
    When I turn on my laptop, I get a 0190 critical low battery error and it shuts down. Now it is plugged in, but it still happens. What should I do to get it to charge and then boot up?
  • Anonymous Mar 27, 2014
    The camera LED is also ON, but the screen is black. As if, the laptop is not booting
    Genius:
  • 2,028 Answers
Try removing the battery and starting it up just on the power supply.
Posted on Jun 12, 2008
  • 24 Answers
Disconnect the AC adapter and remove the battery, then press and hold the power button for 10 seconds. Connect the AC adapter but don't install the battery. Press the power button and see if the laptop powers up. If it does not power up, test the AC adapter output voltage with a voltmeter or try another AC adapter that provides the correct voltage / amperage. If the laptop powers up with only the AC adapter connected. shut it down, disconnect the adapter, and install the battery. Then connect the adapter and try to power the laptop up again. If the battery is completely drained, you may have to let it charge for a while (10 to 30 minutes) before the laptop will turn on.
  • 114 Answers
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Please I hope someone can help me. The laptop is stuck on the reboot and select proper boot device screen.. i can get to the bios though
unplug your laptop, remove the battery and wait for three minutes. then install back your battery and power on. right after you power on your laptop press shift key together with f9. release the keys when the laptop begin to boot. follow the instruction on the display.
Sep 04, 2015 | ASUS X551MA-DS21Q 15.6" Notebook - Intel...
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Sep 12, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
My Toshiba Satellite laptop does not fire up at all. Yesterday as I was working the screen blinked a few times and went dead. I can't get it to come back up. Tried connecting to an external monitor but it...
Four possibilities come to mind.
1. Your power supply is bad and the battery ran down.
2. Your system board died.
3. You have a bad device plugged into a USB port.
4. Your battery is bad and holding down the AC power.
To troubleshoot, disconnect all external devices, even remove the CD drive if possible. Try to boot.
Next, boot with just the battery.
Next, boot with just the AC supply.
That's about it. If you still have no power at boot, it is the system board.
Apr 27, 2010 | Computers & Internet
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
No screen
Sounds like it was already shutting down or going into standby when you plugged it in.
If this is the case, remove the AC adapter and battery then press and hold the power button for 30 full seconds. This will break the stuck power cycle it's in. Once you've done that replace the battery, plug the power in and turn it on. It will most likely give you an error regarding either not shutting down properly or not being able to load the hibernation file. In either case acknowledge and disregard the error then it should boot back up normally.
If this doesn't work, respond back here with whatever additional info you can and we can persue the other possibilities.
Hope this helps FixYa,
Chris
Jun 07, 2009 | ASUS Computers & Internet
Gateway M305 Laptop
Check to see if the monitor shows up in the device manager. Right click 'my computer' click 'manage' click 'device manager' look for any yellow question marks beside the 'monitors' heading.It is possible there might be a loose connection. You should take it to a shop (unless you comfortable dismanteling your laptop) and have them check it out. I hope this helps. Let me know how you made out, and please rate my answer. Good luck!
Jan 09, 2009 | Gateway M305CRV Notebook
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Lenovo 3000 N100 0689 Notebook Logo
312 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
