Question about JBL PB10 Subwoofer
JBL sub PSW-D110 hums, and the fuse is blown
Hi,     I have a JBL subwoofer modeled PSW-D110 and the fuse is blown.  if I replace the fuse, it hums.  There are several components seem blown.  One of the cap is blown, can't read the value of the cap(C24).  Does anyone know the value of the cap.  Does anyone have the schematic for this sub?  please send it to me if you have it.  I read it on the forum that it could be the s53ami causing this problem.  Can some confirm this, because I don't want to spend the money to buy the part if this is not the problem.  Your help will be greatly appreciated. Thanks.  please also send me the schematic for the s531mi component if you have it. fuse keep blowing what could be the cause ot if
Try replacing parts listed below first. Less that $10.00
C6 kit as an substitute and the parts are as follows:
The part is available
The part is called: CAP RAD 10uF 100V Bi Polar. BU120/BU80
The Part # is: UVP2A100MPD
The price is $2.70 each, plus shipping and handling (For U.S. orders only).
The part is called: RES CF 20K OHM 1/2W For C6 kit
The Part # is: 293-20K
The price is $1.98 each, plus shipping and handling (For U.S. orders only).
The part is called: RES mf 47R OHM 1/4W For C6 kit USE -RC
The Part # is: 271-47
The part is called: CAP MCER AX 100NF 50V For C6 kit
The Part # is: 75-1C10X7R104K050B
The price is $1.90 each, plus shipping and handling (For U.S. orders only).
The part is called: Instructions, Kit (C6 repair) Gen brand
The Part # is: C6KIT INST
The price is $2.01 each, plus shipping and handling (For U.S. orders only).
If you are not in the U.S. please advise where you are so the correct information can be sent to you.
Please add tax if you live in New York (8.25%), New Jersey (7%), Connecticut (6%), California (8.25%), Florida (6%), Arizona (8.10%), North Carolina (7%) & Georgia (7%).
You can order this item by calling us at 800-422-8027, 800-336-4525 and 800-553-3332
Please allow 7-10 business days for shipping
Posted on Jan 19, 2011
What is the size of the JBL PSW-D110 fuse?
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
Jun 24, 2011 | JBL PSW-D110 Speaker
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
JBL PSW D100 blown fuse
Not likely. There are no fuses according to the instructions I found for the D-110. I assume they're about the same.
Try it with nothing attached anywhere except the power cord. No light immediately = dead.
Nov 10, 2008 | JBL PSW-D110 Speaker
No output from d110
Hi Chadwik
The fact that you do get hum when you partially remove one of the RCA's would tend to say that the output stages are working ok. Is the hum "solid" and bassy, or distorted?
There are a few issues that these subs have had, mostly to do with capacitors in the power supply failing. If you are up to it, I can talk you through repairs to it.
regards
robotek
Jun 16, 2008 | JBL PSW-D110 Speaker
My JBL PSW-D110 started humming loud... The fuse is fine and the power LED displays is illuminated in green. However the sound is unbearable... It would like to replace the entire IC panel if its most cost...
Hi calsunbelt
there are some caps that fail in the power supply. If you are up to doing some electronic repairs, I could talk you through it and tell you what parts to check.
regards
robotek
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
JBL PB10 Subwoofer Logo
685 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
