Question about HP LaserJet 3055 All-In-One Printer
Printing light strips
We've changed the 12A ink cartridge and the printer still prints a faded out stripe down the left of the page. It was also having this problem before we switched the ink cartridges.
    Sergeant:
  • 329 Answers
Possible bad fuser assemble, on this model very hard to see, have to almost take fuser out to see if worn. Also make sure gmall **** glas on top were the paper feeds over is not dusty...
Posted on Jun 12, 2008
Hi! I just changed my print cartridge (HP LaserJet- C7115X, ink 15x) and the printing quality is still low! It's as if it's still running out of ink, however the cartridge is brand new. Please help!
Did you remove the strip that the printers ship with? If the pull tab is still in then there is typically enough toner to print a few pages and then it fades out. Remove cartridge and check on left and right hand sides for a plastic loop usually orange. The instructions would have been in the box.
Mar 23, 2011 | HP LaserJet 1320 Printer
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
Uneven black ink printing
This is the problem of the black developer in the imaging unit. Please contact authorised service center they will change for you.
Best Regards
Nov 14, 2009 | Samsung CLX-2160N All-In-One Printer
Printing in strips with gaps
Not sure if you have vertical or horizontal stripes but here we go
Nov 13, 2009 | HP LaserJet 1100 Printer
Dell printer printing blanks pages
? check that you did not leave the pull strip on the cartridge ?
Aug 11, 2009 | Dell Inkjet 720 Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
HP LaserJet 3055 All-In-One Printer Logo
242 people viewed this question
Seeker5211
Seeker5211
