The door switch on my Philco soft line washer dryer model 2304 is f faulty and needs replacing where can l get a replacement from please? l live in cyprus.
Looking for door switch for Philoc washer model # MWS939ZAS2 50 HZ
Posted on Nov 30, 2010
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Philco washer doorlock
The door switch or latch could be jammed and you might have to try and check for the end of the washing cycle to get door latch released.
check this link: Door lock
Oct 03, 2013 | Washing Machines
Dryer not working on Whirlpool Thin Twin
Could you check that model number again?Could you please describe the problem you are having?
Does the dryer run at all?
Check the door switch. When you push and release it you should hear a click. If not, replace with a new switch.
Oct 17, 2012 | Whirlpool LTE5243DQ Combination...
On/off light flashes but machine does not work
Could be a faulty door lock, quite a common prob on this range of washer/dryers.To prove if it is faulty or not, remove door lock, fit a jumper wire between the live and common terminals on the door lock, the terminals are marked L-C and N. if it is faulty, then the washer should work o/k, if still no go, then probably something more serious.
Please rate my solution.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Eric
Jun 08, 2009 | Kenmore 64902 Electric Dryer
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Ge washing machine
Jul 23, 2008 | GE Profile Prodigy WPSE4200A
Power Surge and WD16BA
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
