Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Start-up issue on start up after the windows screen my screen goes black and never gets to the desktop
  • 24 Answers
Could be a software/driver problem or a hardware problem. Try booting into safe mode by pressing the F8 key when the Windows screen first appears. If you are able to get to the desktop then the problem is most likely with a driver or some software application. Check for any installed updates or driver changes. Also check for spyware or virus problems.
If the computer won't boot into safe mode either, then the problem could be hardware related. Reseat the memory and try to post the system. If you have more than one stick of memory, try booting Windows with only one stick at a time installed.
Make sure you power off the laptop and disconnect the AC adapter before removing or installing memory.
Other causes of the problem could be a corrupt Windows file or a defective hard drive, or a heat related problem (bad CPU fan or blocked cooling ducts). One way to verify the hardware function is to boot from a live CD like Knoppix or Ubuntu Linux. You can find out more information on either of these operating systems by Googling for them.
Posted on Jun 12, 2008
    Sergeant:
  • 329 Answers
As it boots up depress the F10 or the F 8 key till the bios comes up, there should be a restore feature. Try to restore computer to original configuration...
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Windows wont start
Use your Windows 7 CD to enter Startup repair.
Oct 22, 2012 | Gateway 500XL PC Desktop
Comes on to start screen and goes right back to start screen will not start al the way
If a Windows machine, press F8 during bootup to get into the startup screen and select Safe Mode. If you are able to boot to the desktop, launch the System Restore and restore the system files to a restore point that is before you started having this problem. System Restore is in All Programs -> Accessories -> and if not right there it will be in System Tools.
Jun 09, 2012 | E-Machines eMachines Desktop PC
Whats the problem when the computer boots the loading process bar of windows xp is displayed but as soon as the computer goes into windows xp the screen turs black and stays black
In this situation you need to do one solution to know the exact issue with you system, there are chance that your screen resolution has gone bad or your OS has gone corrupted. You must press f8 when your computer start's and then you must chose start with safe more or start with VGA mode. If you can see you desktop this time you need to adjust your computer's screen resolution as it's seem the problem with your screen resolution.
Apr 15, 2011 | HP LaserJet 1320 Printer
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Feb 14, 2010 | Computers & Internet
My screen goes black after startup
Try a different monitor, I am sure this sounds overly simplistic to you but, I have seen in my customers have just that, a bad monitor.
If another monitor does the same thing, then you should try another video card. If the video in on the motherboard, there should be a AGP, PCI-e, or an empty PCI slot to put a video card in.
Aug 08, 2009 | HP Computers & Internet
Windows starts to set up then screen goes black and
9 times out of 10, the finger points to the power supply.
Replace it and try again - I reckon you'll be good to go!
Apr 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
I cant get windows to connect on in seens stuck?
master boot record is damaged you need to format the drive
Mar 12, 2009 | HP Pavilion a1440n PC Desktop
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
