Question about Mitsubishi WD-73734 73" Television
I have a Mitsubishi wd-73734' and lately the unit powers off and the red timer indicator is flashing on the front panel. After unplugging set for a few hours it works ok,what is causing this thank any info appreciated. Taylorcmatt@gmail.com
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Look for info in the Service Guide found here: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
Posted on Dec 16, 2011
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Projection TV WD-62525
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
Dec 10, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-73734 73" Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
