Question about Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration 13173
I can not remove the lower spray arm from my Kenmore Ultra Wash dishwasher. There is a plastic knob on the top of the arm that can be turned both left and right--neither way makes any difference. I have pulled up on the spray arm, rocked it back and forth, looked for plastic tabs underneath to push in and release it...nothing works. I am doing this because the machine is not getting dishes clean and I am certain the drain/screen needs to be cleaned. I do NOT want to call a repairperson. Will greatly appreciate any help!
catriver
  • 878 Answers
SOURCE: dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Posted on Nov 25, 2006
  • 1462 Answers
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Posted on Apr 02, 2007
SOURCE: whining noise with Kenmore 16032 dishwasher
I had a similar issue, I removed the lower spray arm (had to hold center plastic tab with pliers and then unscrewed and lifted up the arm). Then I removed the cover with the screen filter(4 screws) and then removed the top half of the stainless chopper housing (1 screw). Found that things like cherry pits, elastic bands, bread plastic ties had blocked the water inlet to the chopper and the area around the chopper blade. Cleaned it all up, reassembled and machine works great! Mine was so blocked that I was hardly getting any water pressure to the upper rack.
Posted on Mar 22, 2008
aborcass
  • 2651 Answers
SOURCE: cleaning out debri in pump
if youve acess below the filter screen ther is only 2 more screws holding down 2 more covers giving you acess to the chopper assy, this is where youll find broken glass and stuff hitting against hte chopper try to break up.. the first of 2 covers lifts right off,,, the second will require sorta prying up and off, beyond this no real acess to any more
Posted on Apr 04, 2008
SOURCE: Kenmore ultra wash III dishwasher
Well, the water is clean. The only thing I can think of is that the pump is just not doing its job. The only way to know is put a meter or a flow meter on the pump but heck, I can buy a new dishwasher for under $300 so I think I will just give up. Hate to do it but it is not worth the time and effort anymore. I really appreciate your involvement in my problem and I hope I have not over loaded you with my questions. New dishwasher, here I come........ bah humbug. Mine was only 13 years old, they just do not make them like they use to.
Posted on Jul 12, 2008
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
How to remove the bottom spray arm on my kenmore ultra dishwasher?
Grab the squarish plastic piece just below the wash arm and turn it counter-clockwise 1/8 of a turn, and it should come right off.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 05, 2014 | Kenmore Dishwashers
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
How do you remove the lower spray arm on a Kenmore Ultra Wash (665.17019.402)? I was told to hold on to the plastic screw and spin the arm counterclockwise to remove, but I've been spinning and...
Hi, In the center of the spray arm is a threaded piece of plastic/bolt.
Use pliers and turn that tab on the bolt. If it doesn't turn easy. Holt the bolt and try to turn the spray arm with you hand.
It will release the spray arm so you can remove it.
Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Dishwashers
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Whining noise with Kenmore 16032 dishwasher
Mar 11, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration  13173 Logo
32 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
